Dual PIII-S Tualatin 1.4 GHz Success Stories
Reply 280 of 327, by TrashPanda
Skorbin wrote on 2022-09-09, 13:45:
I had a GA-6VTXD, but unfortunately it was completely dead. […]
Currently I have a build with an ASUS P2B-DS 1.06 with a pair of 1000/100 slot cpus (yes, i was lucky to get them some years ago), so it's running with stock speeds.
When the project Tyan Tiger 200T is finished I will try to get two more duallies up and running: GA-6VXD7 and GA-BXDS.
About 15 years ago I bought 10 dual boards cheap when nobody wanted them. Unfortunately two were not recoverable and 4 boards went to friendly people from our forum who recapped the other boards for me.
So this still left me 4 boards I am currently experimenting with.
The ASUS is rock solid and is currently acting as part time non-professional backup recovery server for old media (various tape drives, ZIP, etc.), running under Windows 2000 and Debian.
The TYAN Tiger 200T is now also up and running, but will probably see some minor hardware changes (putting the second hdd on IDE channel #2, installing some fan, etc.).
hmmm, I wonder if the P2B_D 1.06 can handle 1gz 133 Coppermines, I have to do the mod to it so I can set the pci/agp dividers correctly. (Asus P2B-DS Rev 1.06 FSB Modification)
And yea them 100FSB P3s are super hard to get now.
Reply 281 of 327, by PARKE
TrashPanda wrote on 2022-09-09, 14:09:
The vanilla P2B_D 1.06 that I have here works with 2x 1gz 133 Slot1 Coppermines but only with 3 sticks of 256 RAM - 4 sticks is a problem.
Reply 282 of 327, by CwF
Skorbin wrote on 2022-09-08, 18:19:
@Kahenraz I think you missed an important fact: this thread is talking about DUAL tualatins. What sense would it make to run an […]
@Kahenraz
What sense would it make to run an OS, which cannot take advantage of the second cpu?
And if you happen to have such a mainboard laying around, wouldn't you try out what is possible with such a system?
I for sure do!
And I can tell you that I also plan to run a low ressource version of Linux on it, probably Debian with XFCE or Antix, maybe even going the hard road with Gentoo or Linux-from-Scratch.
Is this sensible?
For most people probably not, but hey, it's my hobby, my time and my electricity bill 😉
And I think this systen even can "run" Crysis 😀
I have the itch to try to build a Debian i386, maybe with xfce or possibly a ncurses or tickle based reserve machine.
I commented back on page 8. I used my P3TDe6 for over a decade, finally retired about 2015 when I needed it's E-ATX case for a fresh Jessie build. I don't think I'll revisit that board that's now in the original box, should sell it I guess. I was thinking to try the Intel (SA2?) board.
Notes on GPU's. The GTX610 and HD5450 will run @66MHz and it did double basic benches. If I try it I'll use the AMD obviously. In a VM that has already been proven decent.
I have a few 8 port sata pcix card, a few GB networks cards, and 4GB memory, so covered.
Not sure why, but it is an itch. Maybe since i386 is on the chopping block for current linux. Certainly it could have a modern browser, Dosbox, wine...hmmm. I might just write out that image I used for the HD5450 VM and simply try it...
I used to know what I was doing...
Reply 283 of 327, by TrashPanda
PARKE wrote on 2022-09-09, 14:49:
IIRC the BX chipset has issues with 1gb of ram and 133 FSB, hmm 125FSB might allow 1gb of ram.
Reply 284 of 327, by Skorbin
Ok, first coming back about my remark concerning Crysis:
As I already assumed, the words "Crysis" and "running" did not really come together on my machine.
With an average of 8.5 frames/sec on 800x600 and all low settings on the benchmarked demo we can safely assume that this game would not be a very pleasurable experience.
It does "run", though ...
For the BX boards I tend to refrain from using 133 MHz. It is used often, but outside the spec and bears the risk of instabilities.
I rather run inside the specs and have a rock solid machine. Recovering old backups on a instable machine would make no sense.
For speedy things i have different machines available 😀
BTW, I use Debian on the ASUS, running from a 64 gb DOM and it works without any problems.
But as more and more programs use SSE2 as default, I intend to set up my own compiler platform to be able to keep those systems running. I think about using Gentoo.
The Tyan will probably be the native compiler and binhost for the other 3 dualies. Crosscompiling would be way faster but bears the risk of tainting the code with non-native instructions.
Edit:
Scratch the last remark. That Tyan BIOS seems to be extremly buggy and not adhering to the standards.
After some hours of fiddeling with various linux installations (Gentoo, Antix, Debian) and only getting kernel panics I decided to call it a day and limit myself to windows XP now with this machine.
Reply 285 of 327, by TrashPanda
This thread seems to have gone quiet
Holy Moly . .Just checked the evilbay prices for the Intel SDS2 ...one for 3200 USD the other at 4600USD .. WTF
Reply 287 of 327, by TrashPanda
Sphere478 wrote on 2023-01-19, 02:22:
Sometimes if they were used in industrial applications sellers will do crazy prices like that
Its pretty crazy pricing, I thought that 500USD for a Gigabyte GA-6VTXDR was a bit high but seems the other Tualatin capable boards run higher. There is a very nice looking working GA-6VXD7 for sale at the moment, it cant do dual Tualatin without pin mods but it does have AGP with an unpopulated ISA slot, I would take a gamble but its from Kazakstan which makes me wary.
I do own a pair of Gigabyte GA-6VTXDR boards ...sooo .. I might have to hold off on any more dual PIII boards 🤣. (I do want one with PCI-X on it .. have yet to find one at a reasonable price)
Reply 288 of 327, by Sphere478
TrashPanda wrote on 2023-01-19, 02:31:
Lots of good retro stuff coming out of east europe-asia reigon.
I’ve ordered a few things from the countries around there.
Sphere's PCB projects.
Reply 289 of 327, by TrashPanda
Sphere478 wrote on 2023-01-19, 02:46:
Ive had good success buying stuff from Ukraine, stuff from Kyiv even with the war still gets here to Australia amazingly fast, might take a gamble on the board if its still avaliable next month, might make a great modding project to add Tualatin support.
Reply 290 of 327, by luckybob
TrashPanda wrote on 2023-01-19, 01:05:
Makes me happy I snagged 2 in the last 2 months for $100 each. (Ish).
I haven't gotten around to yrst them yet.
Reply 291 of 327, by TrashPanda
luckybob wrote on 2023-01-19, 06:27:
...gimme!
Seriously though, prices for certain items have shot through the roof recently along with shipping and import costs. Im patient however and ill eventually get one of them Intel boards at a price I can live with.
Reply 292 of 327, by sirotkaslo
Prices are a bit high for everything retro related now. I guess now would be a good time to sell one of my Pro266TD Master- LR . 😁
I'm in the process of building a pc with one of them. Dual 1400s, Geforce 4 Ti 4200, Hercules Game Theater XP. Not sure about which OS, do you have any experience using this board in win2k?
Reply 293 of 327, by TrashPanda
sirotkaslo wrote on 2023-01-19, 09:13:
I have yet to obtain a dual Tualatin board with AGP or PCI-X, the two I have only have PCI which with a X1300 is rather nice.
Reply 294 of 327, by sirotkaslo
I got lucky a while back and got two boards. One with dual 1400s and one with 1266. I have only tested quake 3 with it and smp does make a difference there - in winxp. A huge bonus for me is the usage of DDR memory, which is much easier to get to a few GB than with SDR.
That x1300 is of course a beast when it comes to retro gaming, even though it's a bit new if you're into period correctness.
Reply 295 of 327, by TrashPanda
sirotkaslo wrote on 2023-01-19, 10:44:
Its a dual 1.4s Tualatin board with 1gb of Ram on it, not sure where it falls with period correctness but I wanted a card that could haul ass while still on the PCI bus. Its not far off from a Geforce 4 Ti4600/4800 performance wise but its CPU bound as even dual 1.4s cant feed it data fast enough. I did initially think the PCI bus would hold it back but it doesn't seem too bothered by it, I have a ATI HD2400 Pro 512mb PCI coming soon which might be fun to throw in there to see if it makes a difference.
Reply 296 of 327, by sirotkaslo
Yeah it's a bit newer, but doesn't matter really. As far as PCI goes, it's a nice fast card.
Reply 297 of 327, by Sphere478
Whatcha think?
Dual 1.4 tualitin
Two setups:
One with a pci geforce 610
One with fastest agp 3850?
I think these are limited to 3.3? Agp though yes? (Reming me) So would be what a 6800 or a 9800?
Seems like >if< the drivers worked there might be a chance that the pci 610 might actually be best.
But check this out,
There also exist agp to 66mhz pci adapters. So the plot and question thickens.
Reply 298 of 327, by luckybob
As I recall, most dual Tualatin boards had sub-par AGP performance.
I do have a project in the works for my dual tuallies, but I'm not ready to go public with it until I get one last part ....
Reply 299 of 327, by sirotkaslo
I only really tested mine with a Voodoo 5500, but it gave me a similar performance to a KT266 board with athlon XP.
