Asus P5A not working
Reply 40 of 42, by fool
I would order exactly the original type. Then important specs are correct. Transistor type doesn't effect that much on heat generation in this design. Low Rds(on) is better in switchers = lower power loss. Overall regulator structure mostly defines efficiency.
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
Reply 41 of 42, by Nemo1985
That would be wise, but I was unable to find either the 45N03 or the the nec k2941 from tme, where I usually source caps and such stuff...
Reply 42 of 42, by weedeewee
The information contained in this video https://www.youtube.com/watch?v=9wuyPZjjR9k can help you find a replacement.
Do not ask Why !
