First post, by keropi
- l33t++
Hiya!
for some reason, Prehistorik on my setup sends it's midi data on the SB16 mpu (port 300 with a DB-50XG) and not on the MPU401-AT (port 330, irq2, cm-32L) that I have installed.
The "setup" program (just run "prehistorik r") lets me select MT32 music but it sends it to the DB-50XG... CM-32L does not receive any data...
Is there a trick to bypass this odd behavior?
TIA! 😊
