Reply 40 of 82, by Nemo1985
ediflorianUS wrote on 2023-03-06, 15:00:did not read all , but did you change keyboard? seems a kb issue or at least kb input issue somewhere on the line of KB....
Problems are also without keyboard connected so actually it doesn't matter I fear.
rasz_pl wrote on 2023-03-06, 14:16:all behind the coil […]
Nemo1985 wrote on 2023-03-06, 12:49:That's a point, which caps? The one near the coil wire?
all behind the coil
Nemo1985 wrote on 2023-03-06, 12:49:Measure... i'm sorry but about it i'm quite dumb, can you show me where I have to use the tips of the meter?
https://en.wikipedia.org/wiki/PS/2_port
pins 1 3 4 5
also pins 1 5 all the way to superIO chip pins
Ok continuity mode it beeps on pins 3, it should be ok.
Resistance resistance between pin 4 and ground is 0.535 fixed value.
Resistance resistance between pin 1 and ground is 1.4xx and increase, same goes for pin 5.
About continuity between super io chip pins and pin 1 or 5, I got no beeps. So no continuity
TrashPanda wrote on 2023-03-06, 14:35:bogdanpaulb wrote on 2023-03-06, 14:25:Might be the pic , but that trace looks interrupted by corrosion .
They certainly dont look right and since they look like they are going to and from the IDE sockets they might be worth checking for continuity.
Those traces are not in good conditions but to a first glance they are connected to the secondary ide port. If I connect an hard drive to the primary port it gets recognized right from the bios.
I took another picture, it doesn't seem cut but some corrosion is going here?
