First post, by AppleSauce
- Oldbie
Hiya anyone that can help , I've got a bit of a setup in the works involving a DB25 switcher and some LPT sound cards.
And I was just wondering if my setup would be feasible or not.
So I've got the printer port and audio cable bits figured out.
But the main issue is supplying power , so since both LPT devices need to be powered by a USB mini A type cable and my pentium motherboard only has 2 usb ports and I want to keep one for transferring stuff via USB, I was wondering if I could this?
So USB mini A would go into the LPT device and the regular A side to the USB switcher ,
which uses USB type B so id use a converter to hook it in ,
then a usb A to usb A would go from the switchers out to the PCs usb port to power it.
I figured id ask cause there was stuff i saw on the web about usb power only being able to go in a single direction and I don't want to blow anything up.
