Reply 48420 of 56760, by Kahenraz
- l33t
Keep in mind that before you make any investment, it's necessary to have a working floppy drive on these Compaq LTE Elite laptops if you ever modify the hard drive. The BIOS is on the disk partition, and if you swap it out, you must boot from a floppy to update the CMOS with the new configuration. The system will *NOT* boot, even if you swap in a working drive from an identical LTE Elite if the CMOS does not already have a matching configuration.
The floppy drive in these is the Citizen W1D which has a perishable belt. If the floppy drive isn't working, replace the belt very carefully! It's extremely easy to knock the heads out of alignment on this drive during maintenance, and realigning them blindly is excruciatingly difficult.
If you have a Compaq LTE series laptop with a broken floppy drive, check the belt!
keenmaster486 wrote on 2018-05-13, 04:27:wrote:You have to be careful not to knock the drive heads out of alignment. Apparently you can only correct this with some complex juju involving exotic proprietary software and an oscilloscope.
I have prematurely greyed many hairs attempting to align floppy drive heads.
I can confirm this.
