Reply 40 of 53, by brostenen
- l33t++
wrote:That's 10µF 16V. But I really doubt it's a capacitor problem. You're saying it starts working after a while, but caps usually get worse when they warm up.
If you have hot air gun, preheater and IR thermometer, I would try reflowing the GPU first.
Thanks for the info. 😀
Hmmm... Then there are some confusions on the net, regarding cap's. Anyway... Checked just one last time today.
Solder joints look crisp and fine. Shiny and new, they look.
Reflowing the GPU! 😳 Hmmm...
Must check this out on the net, on how to do this kind of fix.
There are probably a lot of people having had all sort's of issues with later geforce cards (6000 to 9000 series).
Some tips on do's and dont's regarding this procedure?
