First post, by GTA
hello
does anyone knows on Compact flash cards that works on the Toshiba Portege 300CT or Toshiba Portege 320CT?
Reply 2 of 17, by GTA
theelf wrote on 2023-03-24, 18:34:
GTA wrote on 2023-03-24, 15:41:
hello
Any CF will work
okay thanks, but do you have the same laptop?
Reply 3 of 17, by theelf
GTA wrote on 2023-03-24, 19:11:
hello
Any CF will work
Yes, both, 300 and 320, but are the same anyways.
Reply 4 of 17, by GTA
theelf wrote on 2023-03-25, 00:57:
Any CF will work
thats true they both the same anyways only difference is the cpu and the chipset, but do you have the 300ct model or the 320ct model?
Reply 5 of 17, by theelf
GTA wrote on 2023-03-25, 08:21:
both
Reply 6 of 17, by GTA
theelf wrote on 2023-03-25, 08:59:
both
okay
Reply 7 of 17, by GTA
GTA wrote on 2023-03-25, 09:53:
both
okay
but also does it is better to use hard drive or a compact flash for the toshiba portage 300ct or 320ct and for win98 se?
Reply 8 of 17, by theelf
GTA wrote on 2023-03-25, 15:00:
Im a big fan of CF less noise and faster, but less capacity and expensive
win95 works great in Cf cards i use my 320 for years with a 16GB and still works peefect
remember too, the 300/320 have the hdd in the corner and is not easy to put a CF>IDE
I think the best is you buy something like this
18.95 KiB
Reply 9 of 17, by GTA
theelf wrote on 2023-03-25, 15:59:
Im a big fan of CF less noise and faster, but less capacity and expensive […]
okay
okay, but also how much ram do you have in your 320ct?
Reply 10 of 17, by theelf
GTA wrote on 2023-03-25, 16:05:
64mb
Reply 11 of 17, by GTA
theelf wrote on 2023-03-25, 17:31:
64mb
okay, im also thinking on upgrading my 320ct to 96mb ram
Reply 12 of 17, by GTA
64mb
hi but also i want to know does the 300ct or 320ct will see a drives that are 120gb? i just need to know
Reply 13 of 17, by GTA
64mb
please replay
Reply 14 of 17, by theelf
GTA wrote on 2023-05-07, 08:22:
64mb
No idea bios limit, but anyways, if for some reason bios limit to 32gb, you can use ezdrive or similar overlay,that support up to 137gb
Reply 15 of 17, by GTA
theelf wrote on 2023-05-07, 18:54:
64mb
okay, but the reason i asked you this quistion is because im thanking on buying 120gb sata m.2 ssd with ide adapter, and the 120gb is the smallest and cheapst i can find in my store, is it a good idea for storge for retro laptops like this? if it is cheap
Reply 16 of 17, by theelf
GTA wrote on 2023-05-07, 18:58:
The ideal is a 16/32GB CF card with ide addapter,100% guaranteed to work, but if a SATA SSD fits and the SATA>IDE converter works fine, no problem, but is a hit and miss, i dont think nobody knows until test
