First post, by ontrca
I bought 3 of these new in the box.
None of them work in a PC.
I Googled them and I can't find anything, can someone help me? (:
Reply 1 of 29, by Deunan
It won't help you much but I'm going to state the obvious: You don't put a PLD on a floppy drive, a piece of tech that was pretty much perfected into single LSI chip by the time HD 3.5" drives were introduced, for no reason. And also it looks like the drive control might be non-standard, some of the odd-numbered pins look to be connected to some signals rather than GND.
Since it's a Sony make sure you are connecting the ribbon the right way, there's a cutout on the PCB for the notch on the plug and that seems to be in correct position but if the drive has a plastic connector rather than bare pins it might have another cutout on the wrong side. Sony was notorious for doing this for some reason. Rather than trust the cutout/notch pay attention to the pin numbering on the PCB silkscreen and make sure the colored wire in the ribbon is indeed on pin 1. If that still doesn't work then take a closer look at the jumper block, make sure it's set correctly to drive 1 (assuming it starts at 0, if it starts at 1 then you need to set drive 2).
Reply 2 of 29, by konc
The model number doesn't seem to correspond to something special. Unless Deunan is spot on with his observations of course!
Reply 3 of 29, by mdog69
Look at the solder blobs to the right of the connector marked SH19. Remove the DS0 blob and make the DS1 blob and try again with a PC.
Reply 4 of 29, by ontrca
I'll try it 😀
Reply 6 of 29, by ontrca
mdog69 wrote on 2023-05-08, 22:46:
I tried, but it didn't work.
Reply 7 of 29, by sangokushi
ontrca wrote on 2023-05-09, 01:07:
Does it mean the PC BIOS cannot detect the drive?
Or inserted a floppy disk and the drive cannot read it?
Reply 10 of 29, by Deunan
Huh, there is a solder jumper for the drive select, I never noticed it. I figured that would be set via jumpers.
ontrca wrote on 2023-05-09, 04:06:
They cannot be recognized by the BIOS so they cannot read a floppy.
Are you setting them up at 1.44M? Did you try turning on floppy seek at boot option - is there head movement? Is there anything, like the busy light at any point?
Reply 11 of 29, by ontrca
Deunan wrote on 2023-05-09, 08:37:
I don't know what the jumpers are for.
Reply 12 of 29, by Deunan
ontrca wrote on 2023-05-09, 11:00:
These probably control some of the non-standard features of these drives. But the important thing is what did you set in BIOS? Is the floppy set to 1.44M? Is the seek on boot option on?
Reply 13 of 29, by Tetrium
ontrca wrote on 2023-05-08, 18:11:
Pics of the box?
My retro rigs (old topic)
Report spammers here!
Reply 14 of 29, by HanSolo
There's still an auction on ebay with many of them (from California)
Reply 15 of 29, by eesz34
As another user mentioned, it is very strange to have an Altera part on a supposedly standard floppy drive. Unfortunately there's no information on the Sony branded chip.
I don't know if you're good with electronics, but if it were me I'd connect power to the drive and try turning on the motor and stepping the head, just to see if that works. If so, there's no reason it shouldn't at least perform a head seek when connected to a computer. It's actually not difficult at all to do this. See https://polprog.net/blog/fdalign/
That web page is to calibrate a drive, but it has great instructions on getting the drive to do something.
Also, have you taken the top cover off to see if there's anything non-standard in there?
Reply 16 of 29, by Kouwes
It’s a different FDD but look at the jumper
Reply 17 of 29, by emote
Back in the day I bought a box of Sony floppy drives and none of them worked in the machines I was building (on Intel branded P4 motherboards). I swapped the drives for a different brand.
Reply 19 of 29, by ontrca
eesz34 wrote on 2023-05-09, 16:29:
As another user mentioned, it is very strange to have an Altera part on a supposedly standard floppy drive. Unfortunately there' […]
I took the cover off.
