Reply 49100 of 56754, by Nexxen
6ABX2V (VER 1.2)
https://theretroweb.com/motherboards/s/lucky- … r-1-2#downloads
I have a newer BIOS I need to dump and take pics in the future.
Came with a Trio64V+ and a noname brand ISA soundcard.
P-II 350 + 128MB of ram (64+32+32).
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 49101 of 56754, by Nexxen
Also got an Asrock K7VTA PRO, but it's not powering on.
Sempron 2800 and 2GB of DDR are ok.
Reply 49102 of 56754, by PcBytes
Nexxen wrote on 2023-05-10, 00:37:
Check the Winbond SIO. If it heats up quickly, it's dead. Had one die that way for no reason, especially as the PSU tested fine.
Reply 49103 of 56754, by AlessandroB
Shponglefan wrote on 2023-05-08, 17:34:
Picked up a pair of Roland MPU-401AT cards. These are my favorite internal MIDI cards and have been challenging to find, so I was glad to acquire a couple more.
whats the function?
Reply 49104 of 56754, by Brawndo
Picked this up for one of my high end XP/early Windows 7 dual boot systems, either the 1366 or Sandy Bridge PC will get it. Haven't tested it yet but it was sold as working so hopefully that's the case.
Reply 49105 of 56754, by Nexxen
PcBytes wrote on 2023-05-10, 03:52:
Nothing getting hot. I'll check it for shorts.
I found a missing cap on the back in the cpu NB.
Edit: hopefully it's a 1000nF like the others around. Need to find one, let's go fishing in my dead stuff pool 😀
Ok, 1µF but under the NB.
Reply 49106 of 56754, by Shponglefan
AlessandroB wrote on 2023-05-10, 04:30:
whats the function?
It's a MIDI interface with intelligent mode support, so it's ideal for using with modules like the Roland MT-32 and CM-series. It also has a wavetable header, so it can be used with internal wavetable daughtercards as well.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 49107 of 56754, by H3nrik V!
BreakPoint wrote on 2023-05-08, 16:55:
Can someone identify this ISA card? I do not want to plug it to a PC before i know what it is.
That black block in the top left corner, looks so RTC or NVRAM like. Could this be a bios add on to mitigate Y2K issues?
Reply 49108 of 56754, by Maryoo
When I see Intel D865 boards with a Pentium 4 3GHz processor for $10 at auctions, I just have to buy them. It's the best retro pc base for DOS and Windows 98 in my opinion. Fast, stable and hassle-free.
Reply 49109 of 56754, by libby
Maryoo wrote on 2023-05-10, 18:20:
I tend to take any Dell Dimension 4600s I see at the recyclers for this reason. Basically the same board and features, in an easy to work on and non-ugly Dell microATX case. they aren't as prone to cap plague as earlier models were. I clean them out and replace the heatsink with a copper one, and it's a turnkey DOS/98/XP multiboot PC that runs almost everything you can throw at it.
Reply 49110 of 56754, by Nexxen
ISA is A151-A00 FCC ID: LWHA151A00
YME719E-S audio chip
Reply 49111 of 56754, by smullyoz
God brand new e-DImensional Stereo glasses (predecessor to nVidia 3D Vision, both work the same way, except 3dVision requires Windows Vista and GF8 as a minimum and doesnt work with CRTs) and a barely used Sidewinder Force Feedback Pro.
Both work like a charm, here with Starlancer under Windows ME.
Reply 49112 of 56754, by dragonkn
nice setup Smullyoz gz
Reply 49113 of 56754, by TrashPanda
Saw this really clean looking pair of XFX Geforce 7950GT GPUs going cheaply as a matched pair, they look almost new with little signs of wear and tear on them.
Both have been tested as working so I guess Ill find out if that's actually true when they arrive, they should fit a QX9650 + XFX 790i SLI board rather nicely.
I think these are the XFX overclocked passive models https://www.techpowerup.com/gpu-specs/xfx-795 … n-passive.b1712
The attachment 7950GT x 2.jpg is no longer available
The attachment 7950 back.jpg is no longer available
The attachment 7950 2.jpg is no longer available
The attachment 7950 1.jpg is no longer available
Reply 49114 of 56754, by PD2JK
Local craigslist and couldn't resist.
Reply 49115 of 56754, by luckybob
Oh that's a score at almost any price....
Reply 49116 of 56754, by iraito
Today i finally got in my hands a decent KVM (Aten CS-84A) which was pretty much required between the work PC, the old one for general use and the retro one;
The keyboard and mouse emulation finally solves my issues at boot.
Also this thing is built like a tank.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 49117 of 56754, by EvieSigma
Drove 45 minutes today to get this Macintosh SE/30. I was so relieved when I cracked it open and found an intact battery instead of an exploded mess. Needs cap repair but they pretty much all do at this point.
The attachment PXL_20230511_174750846.jpg is no longer available
The attachment PXL_20230511_175414786.jpg is no longer available
The attachment PXL_20230511_175555046.jpg is no longer available
The attachment PXL_20230511_180344421.jpg is no longer available
Reply 49118 of 56754, by eesz34
EvieSigma wrote on 2023-05-11, 20:09:
Love it! I'm not an Apple person but still find them interesting. And was getting tired of all the stuff in the thread from this millennium :- P
Reply 49119 of 56754, by Meatball
I picked up a few K6 family processors, including one modified into a K6-III+. The last time I owned a K6 was at the end of 1998; K6-2@380MHz.
