First post, by stu_e_hughes
Hi everyone,
It looks like i'm forced to put my P100 AT MB in an ATX case so I will have no Turbo button to connect to.
What solutions are out there so that I can turn my turbo on and off from outside the case? Doesn't have to be fancy. Just functional. Thanks.
Reply 2 of 3, by Boohyaka
Maybe your mobo supports a soft shortcut (usually ctrl shift +/ctrl shift -, or ctrl alt +/ctrl alt -) so you can live without a physical switch?
Reply 3 of 3, by stu_e_hughes
Yes, the soft shortcut would be ideal. I will try that when I have my rig setup again.
Are there header connectors with a switch available anywhere to be found if I do want to go down the hardware route?
