I bought an Abit AK3 that was labelled up as an Auva TAM 386. I wanted a 386 board that has physical cache and the possibility for a socket - all of my 386dx motherboards with cache chips don't have room for a CPU socket, but this one does:
It was sold as for parts and wouldn't boot getting stuck at an early post code of 0D or 0E - the traces looked like this to start with and I thought I'd need to run new ones:
They cleaned up really well though - instead of using vinegar I'm just using the flux in some Loctite solder that I don't otherwise like for soldering because it's sticky rosin type flux that's tough to clean off the board:
That wasn't even what killed it I think, maybe the board even worked with the traces looking like that - but there was a bashed trace on the back and some chip pins smashed down into adjacent traces. Also had to repair one via that is almost invisible from the corrosion. Following a recent youtube video I watched I tried clearing the via's hole with a fine needle then ran the replacement trace through that:
Oh and that 10k resistor pack had pin1 fall off when I tried to measure it but I cleaned the epoxy of the package back a bit and soldered a pin on there, now that's working again in place.
Fired right up, now it gets a socket and I need to figure out how to disable an onboard 386 to allow the socketed one to operate.
