First post, by Hoping
I have a Fujitsu D3128-B25 motherboard, which isn't exactly very old, but it's already ten years old.
It turned out to have a corrupt bios and some bent pins on the socket, but the pins were easy to fix.
With a CH341A programmer and I was able to program the BIOS that can be downloaded from the Fujitsu website but I learned the hard way that by completely erasing the BIOS chip you also lose the MAC of the network card and the Intel management engine firmware.
Restoring the MAC of the network card has been easy but the firmware of the Intel managent engine, I have not been able to restore it despite my attempts and my searches in google.
As a note, I have another motherboard just like it and it works fine.
The reason for wanting to restore something as useless as the management engine is that in the bios system monitor and also during the boot process an error is shown in sensor 1. I have not been able to find specific information about this sensor, in the BIOS only indicates sensor 1 error and during the boot process the boot stops.
For example, from windows with hwmonitor, it has been impossible for me to know which sensor is failing since there does not seem to be any problem.
In summary, does anyone know how to program the part of the bios that contains the management engine if it is not present, or some way to make a complete backup of the BIOS of the motherboard that works correctly by software and program it in the other one by software or with the programmer, I am only worried about using the programmer on the motherboard that works properly.
Edit, it is sensor 1 not 2, corrected.
