First post, by nickpunt
Hi there, I have a no-name P55C socket 7 board that I'm trying to identify that I was hoping some may know more about. After searching the BIOS boot label (2A59CPA9-00) and looking at the features & jumper similarities, I believe it is a variant of the Epox P55-IT, but I cannot find it in the The Retro Web database.
Features:
* Size: 8.75"H x 10.5"W
* Award BIOS 4.50GP date 04/20/1995
* On boot, BIOS shows TRITON-2A59CPA9-00 at bottom
* Only labels on board say "Rev 0.2" and "Made in Taiwan"
Chips:
* SMC fdc37c665gt - floppy disk controller
* VIA VT82C42N - keyboard
* SST 43M1BAA 28EE011 - bios i believe
* VIA VT82885N - realtime clock
* 256k cache (according to jumpers)
* Intel 430FX chips, with BCC 8160 sticker on one, and 2x 72pin ram with BCC 8179 stickers
Jumpers
* P54C and P55C
* Pentium 75, 90, 100 (what I believe is 50, 60, 66mhz bus)
* 3/2, 2, 3, 5/2 multipliers
* 256k or 512k SRAM Tag cache
Features
* 4x 72pin ram
* 4x PCI
* 4x ISA 16bit
* Socket 7 without VRM
* No COAST chip
* AT Keyboard, IDE x2, FDC, Serial/Parallel (w irq jumpers)
My hope is to get the right BIOS update for it and if there's any custom BIOS to allow different CPUs.
Thanks!
    1.77 MiB
Reply 1 of 6, by Horun
The BIOS ID string does match Intel Triton FX and Epox. Being a Rev 0.2 seems very odd, usually they start with Rev 1.0...but saw a few Epox with it, an IT and a ET with same rev #
so think your thought on Epox is correct. Went thru my EPox archives and found some stuff, one link listed this: http://web.archive.org/web/19970410145646/htt … x.com/bios.html (the TW site has nothing that oild I could find)
shows 3 diff P55-IT variants. The bios for the SMC has this ID: Award.01/13/96-i430FX-2A59CPAIC-00 and is same BIOS as: https://theretroweb.com/motherboards/s/epox-pronix-ep-p55-et
also found the 8/1995 bios for P55-IT with this string: Award.08/04/95-TRITON-2A59CPA9C-00 which matches yours
Too bad you have a soldered eprom, if it were socketed be easy with a TL866 to save current and flash with the newer one and test, then if not working reflash back.
fwiw: The BCC stickers are most likely some small computer shops part numbers (like Bertha's Custom Computers # 🤣).
attached all the P55-IT various bios found and html from archive with description...
Reply 2 of 6, by nickpunt
Thanks @Horun! After more digging I discovered this is the Epox EP-P54C-IP board and have submitted the info to TheRetroWeb. I'm going to try to dump the flash and flash something newer, as it's having a hard time detecting any drives I throw at it. You're right about the BCC stickers, it's from the Business Computer Center haha.
Reply 3 of 6, by Chkcpu
nickpunt wrote on 2023-06-01, 00:48:
Hi nickpunt,
I’ve found ‘something newer’ to flash for your Epox P54C-IP board! 😉
It is a 03/16/2000-i430FX-2A59CPA9C-00 BIOS update for your board from Unicore Software that comes with the Evergreen Spectra K6-2/400 upgrade CPU package. This 03/16/2000 BIOS does not only break the 8GB barrier but also fixes the 32GB and 64GB HDD limit bugs for full 128GiB HDD support!
In addition, it supports all socket 7 CPUs from Intel, AMD, Cyrix, Winchip, and Rise. So also the K6-2+/K6-III+ are supported.
2A59CPA9.zip
94.35 KiB
25 downloads
EP-P54C-IP 03/16/2000 BIOS
Cheers, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 4 of 6, by Horun
Chkcpu wrote on 2023-06-03, 11:45:
I’ve found ‘something newer’ to flash for your Epox P54C-IP board! ;) It is a 03/16/2000-i430FX-2A59CPA9C-00 BIOS update for you […]
2A59CPA9.zip
Cheers, Jan
Great ! Did not even think of looking in the Evergreen utils for an update.
Reply 5 of 6, by Chkcpu
Horun wrote on 2023-06-03, 14:03:
Hi Horun,
Yes, that Evergreen Spectra Utilities CD v4.0 is a real treasure trove of early socket 7 BIOS upgrades!
It was great that 2 years ago user RichardG867 was able to decode this CD-ROM and made these about 3600 BIOSes available for download at https://archive.org/details/evergreenspectrabios 😀
Only recently I became aware of this great resource, thanks to one of vswitchzero’s excellent videos, the one about the Evergreen Spectra 400 upgrade CPU:
https://www.youtube.com/watch?v=XJRhFU27Wl0
I just saw a message from evasive about the huge task of incorporating all these BIOSes in TheRetroWeb database. I hope you guys can pull this off and have these BIOSes on TRW in the near future. 😀
Jan
Reply 6 of 6, by nickpunt
Hi nickpunt,
Wow thank you so much Jan! I'll give this a shot when I crack open the old ratrod again 😀
