First post, by Per
Hi
I got a Kontron IP LITE, but it did not come with a power supply module. Does anyone know the pinout of the internal power supply connector on the backplane? I'd love to try getting this up and running.
Hi
Is that one of the old Kontron that requires the EISA back plane ? I remember searching for info on one of the old similar Kontrons but their archived website gave little info.
Horun wrote on 2023-06-24, 01:47:Is that one of the old Kontron that requires the EISA back plane ? I remember searching for info on one of the old similar Kontrons but their archived website gave little info.
Yes, EISA backplane, with two main cards making up the meat of the system. The PSU should have connected with an edge-connector in the lower corner of this backplane, but in my system there's only a passthtough breakout cable there for an external PSU module (which was missing).
Found nothing and All I can offer is my web archive text with some Kontron links. Maybe you get lucky searching/adjusting those searches.
Kontron - Kontron Europe GmbH (Headquarters)
https://www.kontron.com
http://www.kontron.de/
http://www.kontron.com.tw/
http://www.kontron.cn/
http://de.kontron.com
http://web.archive.org/web/20040304151137/htt … ww.kontron.com/
http://web.archive.org/web/20050307191912/htt … kontron.com.tw/
added: you probably already found this: https://www.reddit.com/r/retrobattlestations/ … ontron_ip_lite/
pointers to Mr Slugs for the EISA files...
