First post, by DOS Retro
First of all, English is not my home language, so if i type anything wrong, i´m sorry for that.
I bought a computer. It is an 286PC with a 12MHz processor.
When i got home with it, i created a boot floppy for MSDOS 6.22. It boots from the Floppy, and i can play some games with it from floppys.... So that part is functioning.
But the thing is, it has a Hard Drive in it. It is spinning up ,so the motor is good. But when i try to access C: or D: it gives that there is no C or D drive
When i start MSD from MSDOS 6.22, it only gives me the A: drive under Drives.
After that i tried to start Fdisk, maybe that that program can show me more info. But it also gave me the "No Harddrives found in this system"
When i start the PC, it first gives me a sceen from the Video BIOS, after that there is a one liner showing the RAM OK, KB OK and FDD OK. the rest of the screen is blank/black
What i know about the Hard drive is, it had a 34 and 20 pin Flat cable. And also the Molex connector for power and its a 5,25inch model.
About the Mainboard, i know its from Mitsubishi? It Shows "Mitsubishi Electric Corp¨. I tried to google for some numbers and the IBI.M4V0, but didnt give a good result.
Anyone who knows anything about this machine?
161.84 KiB
278.66 KiB
92.92 KiB
Reply 1 of 4, by Grzyb
Can you enter the CMOS Setup?
You need to enter the HDD parameters into CMOS...
https://arvutimuuseum.ee/th99/h/txt/1806.txt
Reply 2 of 4, by DOS Retro
Grzyb wrote on 2023-07-08, 11:16:
Thanks for your help.
The next question would be, how to enter the BIOS? It does not show a message to enter the BIOS.
But after the Video BIOS, i tried different keys, all function F keys, del, insert, home, control, shift.
I heard from someone i need a "g-setup program" on floppy to enter BIOS, but i dont know anything about that.
Reply 3 of 4, by PC Hoarder Patrol
Possible page on TRW, but no moe info - https://theretroweb.com/motherboards/s/mitsubishi-ba803
Give gsetup a try
GSETUP.zip
24.29 KiB
35 downloads
Reply 4 of 4, by Shponglefan
In case it helps anyone, there are a number of BIOS utilities for 286 systems available here: https://ibm-pc.org/utilities/system/system.htm
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
