Reply 24620 of 27784, by OSkar000
80386SX wrote on 2023-06-13, 23:20:OSkar000 wrote on 2023-06-08, 20:55:Tried to get some more life signs from my HP Vectra XU 5/90 today.. not much to report unfortunately. […]
Signs of life!I would say its orange and yellow. Not mentioned in the manuals that I have found so far.
The cpu gets warm
Chips on the motherboard gets warm
Keyboard blinks at start
Soft power on/off works most of the time.IMG20230608223838.jpg
I have tested with one and two known good Pentium 133 and two sticks of FPM memory, also tested and working.
Any ideas 😀
Maybe check the internal of the power supply (capacitors, etc).
Keep the move, HP Vectra XU 5/90 it's a very nice machine.
I forgot to answer this post a while ago.
The PSU looks fine and gives correct voltages under load. But it is probably a good idea to spend some more time and check that everything is ok.
I did put a post-card in it and it doesnt show anything. The cpu and other chips gets warm but no other good signs of life.
