First post, by Zachz91
I recently scored an AST Laptop from 1992/93 on eBay. The computer works well; even the 30 year old battery still works and the 60 MB hard drive has no bad sectors. The only problem I have is the power switch broke off. The switch appears to be a single-pole double-throw slide switch. Here are some pictures.
Does anyone have any info on this?
Reply 3 of 7, by chrismeyer6
It appears to be a standard panel mount switch. You should be able to find a replacement on Jameco, digikey, or mouser. As long as you know how to solder this should be a rather simple fix.
