Reply 20 of 22, by Sombrero
- Oldbie
RandomStranger wrote on 2023-07-23, 15:09:NWN2 however, I'd be surprised if it's issues, if there are any, would be on the CPU.
The engine isn't amazing and needs all the help it can get, both from GPU and CPU. Some of the settings are disproportionately heavy and require some serious grunt, but even with low resolution and lowest settings Cedar Mill P4 3.4GHz / 9800 GTX+ couldn't get more than around 30-40fps in the starting village if I recall correctly. So yeah, it does want its CPU and it wants it now if smooth framerates are to be desired.
