First post, by TheMobRules
I have this early Pentium II motherboard, based on the 440FX chipset. Model name is "R653", apparently manufactured by "m-tech":
The problem is it appears to be completely dead. And when I say "completely" I really mean it. When I hook up a power supply (tried several known working ones), pressing the power button results in absolutely nothing. The power supply doesn't even start (or even try to start and immediately shut off, like when there is a short). So no indicator lights, fans or anything else turn on either.
Therefore, I turned my attention to the power-on circuit. On more modern boards this is handled by the southbridge (usually a BGA chip) so if that was the case it would probably be game over. But since this is an early ATX board and there is no BGA filth there may yet be a chance.
Now, it seems the entire power-on/soft-off feature on this board is handled by the ITE IT8680F I/O chip (datasheet attached):
By following the traces on the motherboard, the IT8680F seems to be the only chip connected to the +5VSB line of the power supply. These are my findings:
- When I flip the switch on the back of the PSU, I get 5V standby voltage on pin 78 (VCCH) as expected
- On pin 75 (VBAT) I get the 3V from the CMOS coin cell battery
- Pin 74 (PWRON#) is connected to the PS-ON line of the power supply, again as expected
- Pin 69 (SWITCH#) is connected via a 33 Ohm resistor to one of the pins of the power button header (the other pin is GND) and it is also pulled high to +5VSB with a 4.7kOhm resistor
- The 32.7kHz RTC crystal measures OK, as well as all the passives around the area
- None of the tantalums seem shorted, and there are no shorts on the power supply lines
If I'm not mistaken this points to the ITE chip being bad, otherwise pressing the power button should result in the IT8680F grounding the PWRON# line and causing the PSU to start right?
A common failure scenario on older ATX power supplies was the +5VSB line going rogue and killing whatever was connected to it, so hopefully that was the case here and the ITE chip was the only victim. All the components on the board look pristine, no burn marks or anything weird.
I may be able to get a new ITE chip from UTSource for about $3, but before I start desoldering stuff I wanted to check if anyone has suggestions of something I may be missing here.
Thanks in advance!
