Reply 50300 of 57996, by PcBytes
Welp, sadly it seems that the Chaintech 5IFM 430HX board is dead 🙁
No POST, tested with anything I could think of - different SIMMs, different CPUs (P166 standard, P133, P233MMX, Cyrix 6x86) and even different PSUs. None would get a POST or beeps out of it.
At least the GPUs (GTX 1050 2GB without 6pin PCI-E, XFX HD7970 3GB w/ missing fans) both work, and one has already been cleaned (GTX1050). Waiting on ordering a parts card for the other one. That, or getting a different heatsink altogether. (I don't mind the slightest slapping a MSI or a Sapphire cooler on it, as long as it can use the 4pin fan header that's on the XFX.)
Reply 50301 of 57996, by Artex
Shponglefan wrote on 2023-09-05, 15:33:
Artex wrote on 2023-09-04, 23:50:
Knocked a few more unicorns off the list:
Ad Lib Gold 1000 8-bit ISA (Sealed) (1991)
A sealed Adlib Gold? How many kidneys did that cost you?
Lol Both of mine and one of my neighbors’.
Reply 50303 of 57996, by Joseph_Joestar
The attachment X800GTO.jpg is no longer available
Got this X800 GTO for 15 EUR from my local classifieds. The plan is to use it in a LGA775 build for dual-booting Win9x and WinXP. I did some preliminary testing and it seems to work fine. Drivers installed under Win98SE without too many issues. I did have to remove a bogus "Standard Display Adapter" before the drivers would work, but after that, it was smooth sailing. Still needs a lot more work, but things do look promising so far.
Reply 50304 of 57996, by Shponglefan
CharlieFoxtrot wrote on 2023-09-05, 15:06:
This is what I got today, bought these socket A boards 10€/kg, which practically translates to a 10€/piece. No guarantees if the […]
This is what I got today, bought these socket A boards 10€/kg, which practically translates to a 10€/piece. No guarantees if they work, but they do look excellent and hopefully are at least repairable:
At minimum I'd imagine a few caps might need replacing. They do look in good condition though!
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 50305 of 57996, by CharlieFoxtrot
Shponglefan wrote on 2023-09-05, 16:18:
Yeah, that is something to be expected and I probably change the VRM caps any case. But these look good indeed, no bulging and leaks and boards are very clean overall.
Reply 50306 of 57996, by Kahenraz
PcBytes wrote on 2023-09-05, 15:57:
It's unlikely to help, but did you try deoxidizing and reseating the BIOS chip? If you have a chip programmer and know which version is flashed, you can also try to validate that it isn't corrupted.
Reply 50307 of 57996, by appiah4
Artex posts and I take another month off Vogons to cool my envy..
Reply 50308 of 57996, by Artex
appiah4 wrote on 2023-09-05, 17:43:
Hey there! Good to 'see' you (and good to be back)!
Reply 50309 of 57996, by PcBytes
Kahenraz wrote on 2023-09-05, 17:33:
Already reflashed to latest version with another mainboard (Luckytech P5MVP3 Rev1.3), no dice.
Reply 50310 of 57996, by gmaverick2k
2017 imac 27" 5k 😁
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Main:z440/2699v3/RTX3060Ti/iFiZenDAC/T480 IPS
98:KT333/AthlonXp 2500+Barton/V3 3000/Vortex2/SC-55
DOS:SS7/P166MMX/V3 2000/PicoGus
XP:Edge72/3570K/GTX970/X-FiTi
Reply 50311 of 57996, by gmaverick2k
delete
Reply 50312 of 57996, by tobiasrieper
Kahenraz wrote on 2023-09-04, 19:49:
acl wrote on 2023-09-04, 18:34:
tobiasrieper wrote on 2023-09-04, 18:05:
I can get memory to just over 224mhz but core will not go past 172mhz 🙁.
That's the first thing I tried 😁
Wow ! It's impressively low !
Regular 5200 sould normally run at 250 core / 200 mem. Or something like that
I wonder how well this would compare to a TNT2 or a GeForce 2 MX, 🤣. I suspect that it might even be slower than the GeForce 2 Ultra.
It got about 300 points lower in 3dmark 999 than my tnt 2 (viper 770) I had to return viper as it had bad vram and i didn't fancy swapping the chips. Max core clock i can get is 165mhz stable. Memory goes all the way up to 250mhz.
Ahh well. LF = Junk. I'll keep the box, sell the card. Buy a decent MSI 5200 then sell that boxed and put the money towards. Y voodoo 3 .
Reply 50313 of 57996, by acl
3DFX Voodoo2 - STB Black Magic 3D 12MB PCI (Boxed) (1998) https://imagizer.imageshack.com/v2/1600x1200q70/924/BAgsyt.jpg […]
I wanted to point out that this STB Voodoo 2 seems covered by a "lifetime warranty".
Since STB was bought by 3dfx which in turn was bought by nVidia, I guess you would need to contact them for a replacement Voodoo2. They might have kept a stock just in case.
Reply 50314 of 57996, by DerBaum
Found and bought some Industrial computers for 20 euros each plus 10 euros shipping.Seller pictures:
The attachment f016c6fa-291e-4a80-9346-3812665ceab5.jpg is no longer available
The attachment 96941377-83b2-4ece-bee9-3097a1ffd1ca.jpg is no longer available
The attachment 643c0f92-74f1-41c4-adee-f448d48aea39.jpg is no longer available
The attachment feb20072-2c33-47b8-b051-c975e0760a6e.jpg is no longer available
The attachment 188d25a8-26cf-41de-928c-43db090b45d3.jpg is no longer available
Not sure what they are or if they will even do something else as they were made for...
But... you know... cheap ... 😁
Edit:
Beige one is a Syslogic SDB/COMPACT2-1CE2
Silver one is a Syslogic IPC/COMPACT6 -XS https://www.syslogic.com/eng/xs-box-pccompact6-34634.shtml
FCKGW-RHQQ2
Reply 50315 of 57996, by pentiumspeed
DerBaum wrote on 2023-09-05, 20:13:
Found and bought some Industrial computers for 20 euros each plus 10 euros shipping.Seller pictures: f016c6fa-291e-4a80-9346-381 […]
f016c6fa-291e-4a80-9346-3812665ceab5.jpg96941377-83b2-4ece-bee9-3097a1ffd1ca.jpg643c0f92-74f1-41c4-adee-f448d48aea39.jpgfeb20072-2c33-47b8-b051-c975e0760a6e.jpg188d25a8-26cf-41de-928c-43db090b45d3.jpg
Edit:
Where did you find them? Looked on ebay and is not sure of features and expensive.
Cheers,
Great Northern aka Canada.
Reply 50316 of 57996, by pentiumspeed
Bought a Pentium class SBC by nice quality maker of Kontron on a mini ISA card size. So mini. Could made it into a slow PC with sound card for even mini PC. 😀
Cheers,
Reply 50317 of 57996, by DerBaum
pentiumspeed wrote on 2023-09-05, 23:02:
Cheers,
I found them on a german selling site. www.kleinanzeigen.de
I found some documentation about the newer silver one, and it seems to be x86 (AMD Geode) and compatible to dos, linux, windows ...
The beige one will probably be something similar
FCKGW-RHQQ2
Reply 50318 of 57996, by Kahenraz
acl wrote on 2023-09-05, 19:47:
I'm certain that the response would be along the lines of, "send us your proof of purchase or order receipt."
Although I would be incredibly impressed if a replacement were to be obtained in this way. Please keep us updated no matter the response, for posterity.
Reply 50319 of 57996, by wirerogue
bought what was supposed to be an nos sony cd-rw.
received this item that was made in hungary instead. it's a 2x2x6 cd-rw.
can't find any info at all on google.
the model says br549 which i thought was a joke since that was phone number from the tv show heehaw and apparently also a band.
it does work so i think i'll probably keep it.
The attachment IMG_20230905_174335.jpg is no longer available
The attachment IMG_20230905_175715.jpg is no longer available
