First post, by majestyk
- Oldbie
At the moment I´m experimenting with different BIOS files for my M919 V3.3B/F. I replaced the 4 x 30-pin SIMM sockets with 2 x 72-pin sockets, because 72-pin sticks are cheaper and because I would like to have 256MB EDO RAM. It´s basically a 3.4B/F now and I can keep the fake "Write Back" cache chips 😉
The known original AMI BIOSes all seem to have the infamous gap in the cacheable area between 56MB and 64MB.
Plus as soon as a VLB video card is installed I´m limited th 64MB RAM. When there´s more RAM, the screen gets garbeled when memory count passes the 64MB limit.
So I tried the more recent AWARD BIOS of the Shuttle HOT-433. There´s no "hole" in the cacheable range here, everything´s working fine, but I loose VLB support.
There aren´t too many UMC-based "V-I-P" mainboards as it seems and the few I found have quite old BIOS versions from around 1994, so they lack AMD 5x86 support.
Is there any BIOS that solves all these issues?
This board came with just one voltage regulator populated, so I replaced it by two new ones with very similar electrical characteristics.
The transistors operate in parallel mode so as soon as they differ electrically, one of them takes all the load and overheats while the second one idles.
The electrolytics got beefed up a bit to make the 3.3V line more stable locally.
