Reply 25340 of 27692, by ChrisNonyminus
So to try to fix the issue with my XP PC freezing, I got an Apevia 450W PSU for ~$30...
...Aaaaand it doesn't have that extra 4 pin connector necessary for the computer to boot. Only a 24-pin ATX connector. 😬
EDIT: Oh, nevermind, I can disconnect 4 pins from the ATX connector! Phew.
Reply 25343 of 27692, by Joakim
ChrisNonyminus wrote on 2023-09-21, 14:44:
Aaaaand the PSU won't power the mobo. Pressing the ON/OFF switch turns it on and immediately off. 😒
If it clicks when you turn it on and nothing happens it's the PSU safety mode. There is probably a short somewhere.
Reply 25344 of 27692, by luckybob
ChrisNonyminus wrote on 2023-09-21, 14:19:
Wrong connector. He's trying to use the 4 extra power pins from the main atx cable. Not the 12v aux power.
Reply 25345 of 27692, by ChrisNonyminus
luckybob wrote on 2023-09-21, 15:55:
OHHHHH!
Now I feel even dumber! I found a 12V set of 2 4-pin connectors and slid half of them off like the 20+4 connector. Fingers crossed this works xD
EDIT: It powers on!
Reply 25347 of 27692, by ChrisNonyminus
Anyone have v84.20 of the nvidia XP drivers perhaps? I've been linked to a thread on Nvidia's site where folks with similar cards had the same issue and one of these posters said that installing driver version 84.20 fixed it for him, but the link he posted to the driver's download is dead.
Reply 25349 of 27692, by vutt
So few weeks ago decided start building 486 with VLB since this MB popped up on local auction site. Back in days 486 DX2 was my first PC MB bought for my own money. I did not have VLB version though. Also chipset called Hint Made In Japan was intriguing as well.
I hade to buy all components around 486 system. As you can see on the pic AT keyboard adapter is very sketchy. With 20EUR MB price I was hoping to keep it budget build. While CPU, Memory, IO card is relatively cheap I was surprised by ISA VGA card prices. Actually that CL-GD5428 was the cheapest card in my region. Seller accepted my 32EUR offer. It was advertised as working so all good. Today CPU arrived and to my surprise it posted. MB was sold as is.
Unfortunately I could not find manual for IO card. It might be actually thud since even floppy drive did not work.
    823.96 KiB
Reply 25350 of 27692, by ChrisNonyminus
Joakim wrote on 2023-09-21, 17:19:
v84.20 seems to be available on Nvidias site. Top search in Google..
I don't see it in Google, nor is it the top search.
site:nvidia.com "84.20"
only returns release notes PDFs, too.
Reply 25351 of 27692, by DerBaum
ChrisNonyminus wrote on 2023-09-21, 18:47:
I don't see it in Google, nor is it the top search. […]
https://web.archive.org/web/20190805010747/ht … ternational.exe
FCKGW-RHQQ2
Reply 25352 of 27692, by ChrisNonyminus
DerBaum wrote on 2023-09-21, 18:50:
Thanks.
Reply 25353 of 27692, by ChrisNonyminus
Okay, so the problem is just the 6200. No matter what driver I use, the PC freezes. Using the 4 MX, everything's fine, it's just that DirectX 8+ isn't supported.
With that, 3DMark 2001 at 800x600 gave me a score of 3228 marks, which seems very good (for 2001).
Reply 25354 of 27692, by pan069
vutt wrote on 2023-09-21, 18:21:
I had a quick scan through here but couldn't find it, I might not have looked close enough so it might be worth having another scan.
https://www.arvutimuuseum.ee/th99/c/c16ide_i.htm
Reply 25355 of 27692, by Rav
.I did the first smoke test of my Pc chip M919
With the PCI Diamond S3 Stealth 64 card I just received.
Good news : no magic smoke!
Bad news : I could only test with a 486 SX I had as the motherboard power regulator is dead so... Only 5V CPU allowed for now.
I did order new one on aliexpress but the post stole them so I have to reorder them because I really need them finally.
Once I have all the part correctly working, that will replace the current ALI M1429G based Acer computer.
The M919 + 486SX, RAM run way faster than on that Acer A1GX-2 board + Cyrix 586....
Reply 25356 of 27692, by vutt
pan069 wrote on 2023-09-21, 21:38:
No match on that page...
However after I posted I went and tested card (LPT port) which seemed to be configured and it worked. So card is working. Then spend entire late night searching internet and finally manually probing deferent jumper combinations. No luck.
Then while already bed 1AM while surfing for last time found ebay sale by searching Winbond chip ID i think and found that pic (attached). Had to get up and verify in the middle of night... ...bingo, it worked. So now I'm rocking PicoGUS in 486 and having good life!!
I'm putting here for web crawlers card exact id: "SIO-WB83787-3" So future retro generations can find this pic with jumpers setup - IDE, FDD, Com-s, LPT, game ports should work with this combination.
    582.37 KiB
    808.34 KiB
Reply 25357 of 27692, by ldare1000
Today I tried and failed to set up a Toshiba SCSI CD Rom which is within a Texas Travelmate 4000m Dock.
I downloaded the SCSI Driver Disk which added lines to my autoexec bat and config sys.
All seems good when booting.
There is no guarantee the CD Rom actually works!!
When I insert a CD the light stays on constantly.
Would you agree the drive or dock are faulty?
The speakers and amplifier in the dock work.
Ta
Louis
Reply 25358 of 27692, by GigAHerZ
GigAHerZ wrote on 2023-09-14, 14:13:
Got myself my first UV lamp for erasing EPROMs. It's a 253,7nm wavelength UV lamp (everything under 400nm is good, lower is more […]
It's a 253,7nm wavelength UV lamp (everything under 400nm is good, lower is more effective) meant for sterilizing items. Works really quick - in less than 5min chips are empty.
I can definitely recommend it. I got a 8W variant from AliExpress.
I'm not going to put a link here, as it may disappear at any day, but the title is: 8W 6W Ultraviolet Germicidal Light T5 Tube UVC Sterilizer Kill Dust Mite UV Quartz Sterilizer Lamp 220V 110V For Bedroom Home
And as a result, i used one M2764 EPROM for my XT-IDE now instead of monstrous W27C256 just for those 4kB of tiny XT-IDE.
Bought some tools container, cut out all the inner compartments and taped it all up with aluminium tape. Had to turn off the lights to be able to shoot a photo showing it working. 😜
All comments by fellow people here are serious! You should not run it naked like i did on test run!
