The Soundblaster DSP project
Reply 260 of 1053, by mattw
Maelgrum wrote on 2023-09-30, 19:44:
Now i can try to code real dumper. First version will be dedicated V4.13 dumper as proof of concept.
In order to help further the effort I spent the last few hours in my storage - breathing the dust and doing the heavy lifting, but I found I think good cards for the V4.13 PoC testing:
1. CT3980 (AWE32) with V4.13 DSP
2. CT3990 (AWE32) with V4.13 DSP
3. D-SUB to MIDI cable - even found the Loopback adapter and I already connected the Midi-IN to Midi-OUT: see the attached picture
Also, took 2 motherboards with ISA slots, need to put everything together, but if there are no any further problems even sometimes tomorrow I could have my testing system ready.
    219 KiB
    D-SUB to MIDI Loopback Connection
Reply 261 of 1053, by Maelgrum
sb16dump V0.01 complete.
works with V4.13 only (unpatched, or patch3) , port 0x220, mpu 0x330.
external MIDI loopback (MIDI OUT to MIDI in) is mandatory.
BE WARNED ! this is highly experimental piece of software, so you use it on you own risk.
I dont have any means to test it by myself right now, so may be it does not work at all.
Reply 262 of 1053, by mattw
Maelgrum wrote on 2023-09-30, 20:54:
thank you! I hope sometime tomorrow I will be able to give you feedback...
Reply 264 of 1053, by georgel
This first time after power on I got this log:
SB Reset: done
DSP version: 4.13
MPU-401 init: done
Internal memory dump: done
MPU-401 loopback check: done
ERROR: Dump failed
All consecutive tests lead to failure to communicate with the DSP which is good I think.
Reply 265 of 1053, by Maelgrum
georgel wrote on 2023-09-30, 21:37:
This first time after power on I got this log: SB Reset: done DSP version: 4.13 MPU-401 init: done Internal memory dump: done M […]
SB Reset: done
DSP version: 4.13
MPU-401 init: done
ERROR: Dump failed
Please do power off, on, and try previous version (not last dumper). Comminication OK ?
Reply 266 of 1053, by georgel
This is the first version I am trying. No problem to me because by powering off the operation recovers. I am not worried about halting. The RAM dumps are also created by this one so it works like the previous versions I guess until the last stage when it attempts ROM dumping.
Reply 267 of 1053, by Maelgrum
georgel wrote on 2023-09-30, 21:45:
BTW, it is not V4.13 patch 4?
Reply 268 of 1053, by mattw
  dsp_413_attack (0x0000);
if (error) { error = ERROR_DUMP_FAILED; return; }
if (dump[0] != 0x02) { error = ERROR_DUMP_FAILED; return; }
I guess that's the point at which it fails, but I am not convinced it actually fails - if you use Original DSP chip, then maybe your DSP 4.13 version doesn't actually has byte0 equal to 0x02 (i.e. the Dump we have is made on another card model), I think good next test is to print "dump[0]" value, especially if you use Original and not decrypted and patched DSP.
Reply 269 of 1053, by georgel
Maelgrum wrote on 2023-09-30, 21:51:
No, it is Vibra 16 with incorporated controller. What is more interesting what I considered halting is not halting at all -- TEST-SBP.EXE still recognizes the card and plays music. It is just the state that the card is left that results in the following behavior of your dumper:
SB Reset: done
DSP version: 4.13
MPU-401 init: failed!
ERROR: Cannot SEND cmd to MPU
Reply 270 of 1053, by Maelgrum
mattw wrote on 2023-09-30, 21:52:
I guess that's the point at which it fails, but I am not convinced it actually fails - if you use Original DSP chip, then maybe […]
It must be first byte of LJMP (0x02) (address 0x0000 is Reset vector). On all seen DSP fw, it is 0x02.
Reply 271 of 1053, by mattw
Maelgrum wrote on 2023-09-30, 21:59:
I see. I will try to put everything together from my side tomorrow and we will see what will happen on my two AWE32 with proper Loopback cable, even I am sure @georgel soldered properly the pins to achieve loopback and that's not the problem.
Reply 272 of 1053, by georgel
FYI I have also tried on CT2770 now with discrete MHS chip and the results are identical to those of Vibra 16 card. So you may consider the card out of suspicion. I have other sound blasters to try with if need be, but this is meaningless on my opinion.
Reply 275 of 1053, by Maelgrum
georgel wrote on 2023-09-30, 22:04:
Can you send me memory dumps (256 bytes, MDUMP1/2.bin) from you tested V4.13 ?
Reply 276 of 1053, by georgel
The attached are from vibra16 I guess. But of course the dump will depend on what was previously run with the SB card and on random power-on values of non-initialized bytes.
How is the ISA port 330/331 (or as configured) connected/decoded to the 8052 exactly? What do they trigger in the DSP?
    MDUMP2.rar
    331 Bytes
    29 downloads
Reply 277 of 1053, by S95Sedan
When connecting it directly pin15 <> pin12 it gives a loopback error.
Will grab some ic's and make a proper circuit for it next week when i have the parts.
Reply 278 of 1053, by georgel
S95Sedan wrote on 2023-09-30, 22:53:
I have connected both pairs of pins directly and loopback works nicely. No ICs are needed.
Reply 279 of 1053, by S95Sedan
georgel wrote on 2023-09-30, 23:11:
Yeah, see what the issue is now, setup error.
I have a dedicated mpu-401 card on 330 so pretty obvious why it doesnt work.
