Asrock 775Dual VSTA & Core4Dual thread
Reply 660 of 723, by Danger Manfred
Any source on what BIOS versions support what CPUs? I can't believe how shitty or nonexistent BIOS infofiles are. "Added CPU microcode" without mentioning for which CPUs or CPU series is the best you'll ever get out of them, but 90% of the time it's just the naked .bin file without any information on why you may need it in the first place.
Reply 662 of 723, by Bruno128
Danger Manfred wrote on 2023-10-15, 00:08:
had a different BIOS
This model has socketed ROM, if you have an identical board just swap the flash chip.
About the versions, probably modded 3.19 is best as it supports everything including 45nm.
Now playing: Red Faction on 2003 Acrylic build
SBEMU compatibility reports
Reply 663 of 723, by RETROKOMODO
Hey gang,
I have a 4CoreDual-VSTA and have tried a PCI-E 8400 GS in it - this one https://www.gigabyte.com/uk/Graphics-Card/GV- … -512I-rev-14#ov - but there is no video output. The same card works fine in a couple of other rando setups so I know it works, and I guess the mobo just won't work with certain cards and up? It has the 2.39a bios on it. The patch notes add support for the ATI HD 3XXX/4XXX cards I see, but no mention of Nvidia cards..
I see the GeForce 8400 GS has a rev 1, 2 & 3 transitioning to PCIe 2.0 with rev 2. The reason for wanting to use this card is to compare it with my 8400 pci card in case anyone is wondering why I want an 8400 GS working!
Could anyone tell me the limitations of PCIe GPU support on this board? Is there a list of known working cards or list of ones that don't work? Fastest PCIe GPU for this mobo? That sort of thing.
Reply 664 of 723, by Bruno128
RETROKOMODO wrote on 2023-10-20, 09:05:
Those boards PCIe compatibility is indeed hit and miss.
I had Radeon X600Pro 128MB not POST in it.
There is evidence of: 7950GX2 and HD5870 working.
Reply 665 of 723, by jives11
Hi, I'm a newbie but decided to join having read some of this long interesting thread.
As part of a project to build a dedicated Fold@home rig out of stuff I had lying around https://mr-ives.blogspot.com/2023/11/building … -pc-server.html ,
I tried an ASUS GeForce GT 1030 card in the PCI-E slot and my 775dual-vsta based machine and can confirm it wouldn't boot to BIOS.
Currently running a modest Radeon HD 5450 and that works fine i.e Linux sees it and can run X on it, but FAH can't see the GPU so running on just the Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz. I'm pondering if a CPU upgrade might be easy or not. ?
Reply 666 of 723, by Bruno128
jives11 wrote on 2023-11-03, 09:00:
With the latest modded bios version you can install C2D E7600 which is faster and cooler than E6600. That is, if you don’t take Core2Extreme parts.
Reply 667 of 723, by jives11
Bruno128 wrote on 2023-11-03, 16:32:
Thanks Bruno. my BIOS is the original P3.00 American Megatrends, so guess I'm stuck without a BIOS upgrade ?
Reply 668 of 723, by Bruno128
jives11 wrote on 2023-11-05, 12:23:
Arguably the full potential of this board is reached through the use of 45nm CPUs (Wolfdale) which are indeed only fully supported with a said bios ver. Compatibility-wise you get the same as you would with Conroe but in lower heat output. I don’t see any good reason staying on the stock version.
Reply 670 of 723, by The Serpent Rider
Of course not. That's better than average Core 2 Conroe though.
Reply 673 of 723, by mr666acdc
My build:
4CoreDual-SATA2
Intel Core 2 Extreme QX9770
MSi GeForce FX 5950 Ultra AGP with Elsa 3D Revelator Glasses
MSI Radeon HD 6970 Lightning 2 GB PCI Express CRT Emudriver connected to Sony-PVM14M4E
Sound Blaster X-Fi Elite Pro SB0550 PCI with panel
ESS Solo-1 V1.1 with Serdaco DreamBlaster Synth S2
Cooler Master V750 Gold V2 White Edition Hybrid
Lamptron FC9, DVD Writer and Gotek OLED Mod
CPU Cooler: be quiet! Dark Rock TF2
Windows 98 Second Edition 80GB ATA
Windows XP Professional SP3 500GB SSHD
Windows 10 Pro 512GB SSD
    545.68 KiB
    1.11 MiB
Reply 676 of 723, by The Serpent Rider
The board is only PCIe 1.0, but generally there should be no issues with risers.
Reply 677 of 723, by Sephiroth, The Great
Why does under Windows 98 SE nvidia driver installers (all versions possible) don't detect nvidia GPU but under Windows ME there is no such problems and all drivers versions can see GPU and install even ones not meant for that GPU (they just don't work after installation and ones meant for that GPU work)?
Reply 678 of 723, by mr666acdc
timsdf wrote on 2023-12-16, 15:05:
Looks awesome. QX9770 is certainly fast enough for win98 😁
Is there any problems with riser cable fit / compatibilty? Since motherboard is only pcie 2.0 x4 does the power / signaling work fine?
No issues with Fractal Design FLEX VRC-25 Riser 😀
    551.13 KiB
Reply 679 of 723, by mr666acdc
More pics .
BTW Capacitors markings are wrong on PCB (minus sign indicate the positive).
    811.9 KiB
    844.27 KiB
    1.18 MiB
