Reply 50840 of 58812, by Kahenraz
- l33t
DerBaum wrote on 2023-11-08, 22:39:Is it possible that you measure some connections for me? just beep out some things. nothing fancy […]
CharlieFoxtrot wrote on 2023-11-02, 18:36:I have one 7193-U and it is manufacterd in 1993.
1 is the Pad on the test connector
2 and 3 are the missing pads
4, 5 and 6 are vias.I made a small chart of the measurments i need.
1 to 2,3,4,5,6
2 to 3,4,5,6
3 to 4,5,6
4 to 5,6
5 to 6Thanks in advance.
I expect:
1 to 6
2 to 5
3 to 4
It might not be possible to repair this reliably for insertion and removal. But what you can do is cut away part of the protective housing of a connector and solder a bodge wire from from the pins to the PCB. Then, add some hot glue for mechanical support.
