COMPAQ Contura 4/25CX
First post, by oneceer
Does anybody own a COMPAQ Contura 4/25CX Laptop?
If so, have someone experienced or knows error codes of that laptop? I've recently got that system and it just outputs 3 long and 3 shorts giving no image. I've already tried using the integrated VGA port to switch the screen modes to dedicated monitor but that didn't help. There was a ram extender, but removing it didn't do anything.
Reply 1 of 7, by dragonkn
Do you have some PCMCIA device? If so try to remove
Reply 2 of 7, by BitWrangler
Got an external keyboard or mouse plugged? There was a period where the "PS/2" port on compaq laptops only seemed to be for a numeric keypad and it flaked with anything else.
Reply 3 of 7, by oneceer
BitWrangler wrote on 2023-11-18, 20:23:
Nope, i'm using the built in keyboard
Reply 5 of 7, by oneceer
bump!!!!!!!!
Reply 7 of 7, by douglar
You could try reseating or replacing the main memory ....
The attachment 07637b31-0fc7-40bd-8681-2f92e04870e6.default.png is no longer available
