Creating 80186 Based System
Reply 80 of 98, by mkarcher
kant explain wrote on 2023-12-02, 18:24:
Disruptor wrote on 2023-11-28, 01:43:
kant explain wrote on 2023-11-28, 00:52:
Link don't work.
That's the problem with the internet and referring to a 5 year old thread.
Links may get invalid if the webmaster did not care about compatiblity.
I think the problem is with this site. It seems to have crunched the link rendering it unusable.
That link works perfectly if you obtain a 2019 edition on archive.org. So the issue is definitely not with this site. Try https://web.archive.org/web/20190920113356/ht … odesl-25-amp-30 .
Reply 81 of 98, by Jo22
Thanks! 🙂👍
Now knowing the title, I was able to find the thread on the new forum.
https://forum.vcfed.org/index.php?threads/int … sl-25-30.28757/
That being said, the old forum was much nicer. IMHO.
Reply 83 of 98, by kant explain
Ok, this thread has seemes to die down. But I heard back from the guy who built the Radio Electronics RE Robot. Including the 80188 based robot brain. He offered to send me the whole robot. But I really don't have the room. It migjt be up for grabs. Would anyone be interested in this item? You'd have to pick up the shipping from somewhere in Florida. And the shipping from NJ for the brain board. I need to see it before I pass it on.
*** Permission to Crosspost ***
Reply 87 of 98, by kant explain
The ad I saw was from 2003. Maybe they used the 186 initially. Or maybe not.
Does it matter?
Reply 88 of 98, by Jo22
kant explain wrote on 2023-12-21, 17:09:
http://www.jkmicro.com/Flashlite186.html
Just because it runs dod doesn't necessarily mean it's ibm compatible. Check with the company.
Proto Raspberry Pi.
Reply 89 of 98, by kant explain
From 12/2003 Circuit Cellar Ink:
Reply 91 of 98, by Jo22
kant explain wrote on 2023-12-22, 16:32:
That's interesting.
There are two more 80186 compatible CPUs, it seems (mentioned in R-Engine-L entry) .
- 80MHz R1100
- 40 MHz AM186ER
Reply 92 of 98, by kant explain
There are a number of variants. 80188/86xl, 80c188eb ... a company even produced an 80187 math coproc at one point.
Reply 93 of 98, by kinetix
Did anyone ever build the system (MPX-16) featured in the "Circuit Cellar" section of Byte magazine, Volume 7 Number 11 , 1982 (and v7#12 , v8#1)?
Reply 94 of 98, by BitWrangler
kinetix wrote on 2024-03-07, 01:39:
Nope, but you got me looking at the first article. 120 IC, 5 layer board, that's a project and a half. I see the board listed as available for $300 unpopulated... shows you how multilayer was black magic around then. I didn't see if they published the board layouts, suspect not many people would have been able to do anything with it back then, probably had 100, even 1000 minimum order on a 5 layer. Be interesting to see what JLPCB or similar place would want now. Probably not a super trivial amount, I'd guesstimate $50 if you're lucky. Ideally you'd want to rejig the slots for standard spacing and provide for higher density memory. All the support chips are a PITA to find for a good price too.
Reply 95 of 98, by kinetix
BitWrangler wrote on 2024-03-07, 03:22:
well, they included floppy, 2 serial , parallel and printer port on board. The interesting thing would be if anyone built one, then or later, besides Ciarcia. but , as you said, for that they should have published the board layout, but they were selling the system, so nop. unless someone made their own layout. I he found some old posts around of people who have/had one system
Reply 96 of 98, by BitWrangler
It might actually be easier to digitise it from the circuit diagrams anyway and redo the board layout, rather than force the old layout into modern tools.
Reply 97 of 98, by ccronk
I emailed circuit cellar who claimed they forwarded it to Ciarcia. I never heard back. To read his editorials, before he reaquired the magazine, you'd get the impression he was a petty douche. Too bad though. I was hoping to get into that project.
Reply 98 of 98, by MrBuzzy
FWIW the 3COM EtherLink Plus network card has an 80186. There was a developer kit and IDE for interfacing with it. But I haven’t been able to locate it, might be lost. If you find it please reply.
