First post, by epborden
Another green light P3B-F adventure. Could use some perspectives.
I am currently trying to use it with a P3 Katmai 500MHz and PC100 RAM of assorted sizes. Besides these, I have a GeForce 256 DDR and a Radeon 9000 AGP cards that I am testing with. One USB keyboard attached but I have no PS/2 at the moment. May get a USB adapter if it is required to boot. See attached configuration.
The attachment IMG_2162.jpeg is no longer available
The attachment IMG_2158.png is no longer available
The attachment IMG_2159.jpeg is no longer available
The attachment IMG_2154.jpeg is no longer available
I bought a new EVGA 500 watt PSU to power it everything. Which is overkill but I was advised to just get a new one.
Everything powers up but I am greeted with a green light and no post. No video signal from either card. No configuration of RAM sticks seems to fix it. Swapping cards has same result. Tried reseating CPU. Tried Jumperfree with dip switches all OFF and jumpered with DIP switches in attached configuration (configured to CPU spec). Not sure if it worked before I received it.
At this point I am not sure what else to do. Is the board toast? Hope not as the 1.04 are harder to come by.
Reply 1 of 26, by AppleSauce
Perhaps the bios rom chip has gone bad?
I'm not sure how common it is but I guess its a possibility?
Reply 2 of 26, by H3nrik V!
What if you try without ram? Will it beep then? I had an issue worth an Intel 815 board. Powered on, but nothing. Removing ram made it beep, though. It was three cpu,c that was dead. Another cpu and everything worked ...
Reply 3 of 26, by epborden
H3nrik V! wrote on 2023-12-29, 04:52:
Good idea. I will try it without the RAM in the morning. I'll give it a few more tries before I make it a piece of art in my office 🤣
Reply 4 of 26, by epborden
AppleSauce wrote on 2023-12-29, 01:51:
No idea! I wouldn't know where to get a new one but I can do some Googling.
Reply 5 of 26, by H3nrik V!
epborden wrote on 2023-12-29, 06:21:
Yeah, and if that gives beeps, maybe try another CPU?
Reply 6 of 26, by Karbist
a post card will save you a lot of headache.
Reply 7 of 26, by PC Hoarder Patrol
Your jumpered pic shows dips 1 thru 4 as OFF-ON-OFF-ON (x4.5)...shouldn't it be ON-OFF-OFF-ON (x5) ?
Reply 8 of 26, by H3nrik V!
PC Hoarder Patrol wrote on 2023-12-29, 09:53:
Unless it's an unlocked Engineering Sample, the Katmai CPU should pretty much ignore multiplier settings.
Reply 9 of 26, by epborden
No dice today. Tried powering up with just the CPU in and nothing else. I have a Coppermine 733 coming that I am going to test with some PC133 next. Perhaps it is the CPU. I pulled the CPU from an old Dell Dimension XPS T500 so it's possible that CPU is just no good. If I can't get it to work I think I'll have the board analyzed and recapped because it's such a gem of a board. Feels like I should keep it.
Reply 10 of 26, by epborden
I bought a new BIOS chip for giggles off eBay to try. Probably will have no effect at all but their not expensive.
Reply 11 of 26, by epborden
You're right, I believe I tried both. I may have downclocked it in that pic just for testing but I can also confirm I did try x5 without any luck either.
Reply 12 of 26, by epborden
Karbist wrote on 2023-12-29, 09:07:
I didn't even know this is a thing. This is amazing. Just bought one.
Reply 13 of 26, by watson
I was recently messing around with a dead P3B-F, although it was rev. 1.03.
The symptom was post code C1 (RAM issue) when the VIO jumper was set to 3.5 V.
Then I accidentally discovered that if I set the jumper to 3.6 V, the POST code analyzer goes haywire (POST codes looping at crazy speed).
Of course, I tried multiple CPUs and several sticks of RAM in all of the slots. In the end, I concluded that the chipset is probably dead.
In my opinion, at least some of these mysterious P3B-F deaths (and I've read about quite a few at this point) can be attributed to the idiotic VIO overvoltage.
I wonder what genius decided that it's a good idea to overvolt the chipset and RAM by 0.2 V without even having an option to set it to the stock 3.3 V. Great "engineering".
Hopefully, your board has a different issue and can still be saved - looking forward to the results once you get the POST card.
Reply 14 of 26, by epborden
I have a mini speaker coming tomorrow. The post card is coming Wednesday, unfortunately, probably due to delays around New Years. When I try the speaker tomorrow hopefully I get some beeps and I can report back some more useful information. So there may be a delay once the work week fires up until Wednesday. Appreciate all the help so far.
Reply 15 of 26, by rasz_pl
watson wrote on 2023-12-29, 22:20:
Its not idiotic, thats what was needed for stable 133MHz factory overclock.
Asus really struggled with their initial jumperless bios implementations. P3B-f, A7V, A7V133 all loved to play dead.
I would start by trying slowest possible configuration - 66mhz fsb.
Reply 16 of 26, by Horun
Where did you get the motherboard ? Did you ever see it boot proper...ever ?
raz_pl , good thought ! I keep a old P2-266 cpu just to test slot 1 boards that won't boot on what should be a supported cpu 😀
Reply 17 of 26, by epborden
Horun wrote on 2023-12-30, 02:22:
I guess it's a good question but I'm not sure why I have to say it. As is the case with most of these finds by now we're not exactly picking these up at the store or from our local tech geek with a running example. Where I live I'd be lucky to even find someone that even knows what a motherboard is let alone an old one like this.
Reply 18 of 26, by Horun
edit: The important point is if you know if that board recently worked OK that you know of, if not just say so.
Have you checked the cpu VRM output voltages ?
Reply 19 of 26, by epborden
Horun wrote on 2023-12-30, 03:28:
SHE LIVES! I think the old Katmai CPU was the culprit. I put in the 733 Coppermine today with some fresh PC133 and it booted up!
