Reply 51280 of 53283, by PcBytes
Figured I should update y'all on the BP6. Fixed the power button issue - Q23 was chipped on the base pin. Replacing it and patching a few traces on the bottom got it to power on from the front panel just fine.
Now, onto the recap. I already swapped the odd angled caps @weedeewee pointed out with 820uF 2.5v Lelon OCR polymers off a Xbox 360S "Trinity" mainboard that has a bad XCGPU.
Reply 51281 of 53283, by PD2JK
Nice work. Got the very same problem with an Asus CUBX-E, got to look for small missing or damaged components.
Reply 51282 of 53283, by PcBytes
Thanks. I still have quite a long way to go.
The fans look rather grimey, the fans cables need some routing as they're long as heck, and finally, a BIOS update is in order.
Still can't understand why did the original owner decide to go for those chonky 462 coolers considering the chips are 333MHz Celerons. They're huge!
Reply 51283 of 53283, by DW12
Today I've received an Ensoniq SoundscapeVIVO sound card, that I bought recently:
I'll have to clean it, as it is a bit dirty.
Reply 51284 of 53283, by pan069
DW12 wrote on 2023-12-29, 20:53:
Nice. Looks dusty indeed. Stick it in the dishwasher (no soap) and rise with distilled water and then IPA.
That cap in the top left corner looks wonky...
Reply 51285 of 53283, by progman.exe
PcBytes wrote on 2023-12-29, 18:26:
Slow the fans right down, and run it quiet?
What else could it be? It isn't like people in that era bought Abit boards (with vast ranges of CPU options in the BIOS), and put cheap CPUs on them, to save buying high-end chips because they could overclock them. That would be like stealing from Intel! 😀
Reply 51286 of 53283, by DerBaum
You have to try the FM emulation of this card.
Please report back how it sounds for you.
FCKGW-RHQQ2
Reply 51287 of 53283, by PcBytes
progman.exe wrote on 2023-12-30, 00:45:
For what they're worth, they're from the Athlon XP era, and have a thermal diode attached on the fan wiring. They start out rather slow (something like 500-1000RPM) and then gradually go faster as the heatsinks warm up.
Reply 51288 of 53283, by Jccwu
IDE ISA Cache Controller BusLogic
Reply 51289 of 53283, by progman.exe
PcBytes wrote on 2023-12-30, 04:52:
Someone's missing some sarcasm. Could very well be me, I've skimmed some of the discussion. I have seen mention of overclocking, and maybe you are just being super understated about what I might now embarrass myself explaining 😀
The huuuuuge heatsinks are because that board and CPU combo was a dream overclocking set up. Stick the FSBs to 100, maybe a bit more voltage to the CPUs to get them stable, and boom, dual 500MHz: a 50% overclock.
I had a celeron 300A on an Abit BH6. 100MHz FSB and IIRC one extra notch of volts (up 0.05 perhaps), and I had a middling chip out performing a PII 450 in most tasks. The PII450 was the top of the range CPU at the time. 50 quid versus ~450, from what I remember of prices.
I killed that Abit board, BIOS hacking (well, I found a program that did stuff, and....). Next board, an Abit BE6 I think, was upgraded to a Celeron 533 that I ran at 850MHz. I don't remember it being as stable as the 300A at 450, I think it needed more power and the heat was a bit much. With hindsight, I bet the PSU wasn't good enough.
There was a golden age for overclocking (or maybe I am confusing the colour of my rose-tinted glasses? 😀 ), cheap celeries, over-spec'd boards and PC100 RAM.
I want to say 50% more performance because of the 50% more MHz, but I fear that could be me trying to recycle the megahertz myth that Intel were starting to push back then...... I bet overclockers helped create a climate where that marketing line could even be used.
Your Abit board is now (ahem) a bit elderly, going straight for a sprint is a bit (again!) harsh. But as long at the system works well at 333, then it'd be rude to not try 500MHz 😀
Reply 51290 of 53283, by PcBytes
No worries, if anything I should be the one ashamed as I know zero overclocking yet I own at least 4 ABIT boards 🤣 (BE6-II rev1.2, BP6, IS7-E, IP35 ProXE)
I'll be sure to check up some guides on how to run the Celerons at 500.
They run fine at 333 with default settings for now and I made sure to bump up some of the capacitance during the recap.
I do have the BE6-II that I absolutely NEED to torture with a slotket.
I recently got hold of a proper Coppermine compatible AA370TS slotket (no idea who made it, but it came with a Coppermine 700MHz/100FSB P3, which tells me enough about it) so the BE6-II will also get its run along the BP6.
Reply 51291 of 53283, by Trashbytes
PcBytes wrote on 2023-12-30, 17:05:
No worries, if anything I should be the one ashamed as I know zero overclocking yet I own at least 4 ABIT boards lol (BE6-II rev […]
The BE6-II Rev 2 and BX133-Raid are two of the greatest boards from that era, they are almost the same board aside from the socket and raid parts, that BE6-II you have will certainly be a fun board to torture !
Reply 51292 of 53283, by florian3
lolo799 wrote on 2023-11-24, 13:53:
florian3 wrote on 2023-11-22, 23:37:
Today I received a Mac Wave Maker sound card from Morning Star Solutions that I bought in a Japanese auction. I know pretty much […]
I know pretty much nothing about this card and I also don't have a Mac with NuBus. It comes with a manual in Japanese, driver and MIDI breakout cable.
According to the box it is General MIDI compatible and also has MT32/CM32L modes. Some of the chips on the card are similar to an AVM Summit or a Kurzweil PC88 VGM board ("Marge" and "Homer").
I haven't decided yet if I should try to get a Mac that's compatible or if I should try to get sound out of it by just applying power and MIDI via MIDI-IN. If anyone knows more about this card, please let me know.
You should get a NuBus Mac, obviously!
Is there a manual in the box? Any mention of a website? Could you dump the floppy and upload it somewhere?
I recently acquired a Mac IIci for this card.
Some versions of OMS (a popular Mac MIDI framework, IIRC I used version 2.3.😎 included drivers.
Here are recordings of Doom E1M1 from the card.
https://www.os2museum.com/wp/making-the-simpsons-sing/ has recordings of the AVM Summit and the Kurzweil VGM.
I also made another recording of the TurtleBeach Multisound Pinnacle's Kurzweil synth as a comparison, which sounds very different.
Reply 51293 of 53283, by lolo799
florian3 wrote on 2023-12-30, 23:58:
I recently acquired a Mac IIci for this card. Some versions of OMS (a popular Mac MIDI framework, IIRC I used version 2.3.8) inc […]
Os2world.com has recordings of the AVM Summit and the Kurzweil VGM.
It sounds nice!
Reply 51294 of 53283, by Murugan
Picked this very nice PC up. Never saw the case,never heard of the brand 😀
It was working before I bought it,came home with it and no go. Turns out the problem was: Tantalums on the 12V line,what else...
It's a 286-12 with an undocumented board (very nice blue PCB) made by Essex. It's posted on the Retro Web now 😀
https://theretroweb.com/motherboards/s/essex- … tric-mb286ve_12
Sadly,the full height MFM/RLL Toshiba drive seems not to work. It sounds healthy but the LED stays on,it's not detected and does not respond to the controller card. Replaced it with an XT-IDE which is much quieter haha. Slapped in a CT1600 and replaced the 3,5" drive. Will take another look at the hard drive later on.
Reply 51295 of 53283, by Kahenraz
That is a very handsome little tower. A 286 will be very compatible with old games that are speed sensitive as well. Great find.
Reply 51296 of 53283, by Murugan
Kahenraz wrote on 2023-12-31, 14:59:
Thanks!
I immediately fell in love the moment it was offered to me. It took some tinkering but it's fully working now. This one is a keeper 😀
Reply 51297 of 53283, by PcBytes
Trashbytes wrote on 2023-12-30, 23:12:
Just dropped a 800EB. It no longer crashes and burns like the Hindenburg but for whatever reason it's snail slow. Methinks there's something to do with the In Queue Depth thingy ABIT has in the BIOS.
Nevermind, got that fixed quick and slick. Sporting a 1000B SL5DV 133FSB chip in there with no issues. It took the In Queue Depth changed from 1 to 8 - for whatever reason ABIT sticks it to 1 for all the 133FSB settings.
Reply 51298 of 53283, by mtest001
Murugan wrote on 2023-12-31, 14:56:
Really nice tower. The brand sounds familiar to me.
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB Live! + Sound Canvas SC-55ST = unlimited joy !
Reply 51299 of 53283, by Trashbytes
PcBytes wrote on 2023-12-31, 15:24:
Thats a Rev 1 board right ..they made a few changes for the Rev 2 version, better bios being one of them and a faster IDE controller, hmm perhaps someone here has the Rev 2 board around to test the queue depth thing.
Apparently your 1.2 revision can be turned into a 2.0 just by flashing the BE6-II Rev 2.0 Raid bios onto it, you may want to try that out and see if it fixes the queue depth bug. (2.0 has the updated Abit Softmenu III)
