Reply 51420 of 53138, by Susanin79
Kahenraz wrote on 2024-01-11, 10:00:EISA sounds really complicated. I watched a video from LGR on MCA and it looked equally confusing. Both PnP ISA and PCI "just work". What's up with these other two slots? Is VLB this difficult?
I should check not only two last slots, probably it will works in other slots. Will play with this later evening.
I have never had an EISA boards, this is the first 😀 It would be good to test how it works in compare to the more modern 486VLB
VLB cards so depended from bus speed and it is hard to deal with them if you need to overclock the system.
