First post, by holdencars11
This AXDA3000KV4D was a trash pick from e-waste with an Abit KV7 and huge Zalman HSF. When I unscrewed the HSF, there was a huge amount of thermal paste, and I noticed a Resistor array was part broken.
Am I on the right track for a replacement that will do the job... If anybody has replaced one before? I have quite a bit of SMD experience, but haven't reworked an actual processor before.
https://au.mouser.com/ProductDetail/YAGEO/YC1 … qTKOci2Vw%3D%3D
Ryzen5 1600AF/ASRock B450Mac/16Gb/HD7750
i7 2600K/P67A-C43/16GB/GTX560
i7 960/MSI X58 Pro/8GB/8800GTS
Athlon II x4 620/GA-M56-S3/8GB/8800GTS
Duron 1300/A7S333/512MB/MX440
6x86MX PR200/PC Chips M571/64MB/ET6000
NEC PowerMate1 268 10MHz
And another 40 rigs.
Reply 1 of 5, by Nexxen
102 is the value. They all are 102.
It's fairly easy, just use some hot air but add some solder to make it faster.
Air at an angle (blowing outwards) and it'll come off fast. To solder just use the iron, not air.
Pads are quite big.
It'll be hot afterward. Let it sit or use a fan to cool it down.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 2 of 5, by quicknick
I've stumbled across this problem over the years, I remember one Barton core having a strange amount of L2 cache (64 or 128K) and thus being recognized as "Unknown CPU" due to a broken resistor network. The Mouser part seems to be just right, but I always recovered the part from one of the motherboards in the "dead" stash.
Reply 3 of 5, by Nexxen
quicknick wrote on 2024-01-17, 19:58:
Recently I had one cpu @667 MHz instead of the rated 1800 IIRC.
The array was broken.
I recycled one from another dead cpu. In fact I have a lot of dead XPs. It was even too easy to damage or kill one.
Reply 4 of 5, by holdencars11
All working now!
Reply 5 of 5, by Nexxen
holdencars11 wrote on 2024-01-24, 14:27:
All working now!
Good! I guess it was faster than ever to do.
