Reply 26500 of 27721, by Thermalwrong
dominusprog wrote on 2024-01-19, 19:53:Combine two broken floppy drives into one working drive, also I’ve changed the LED to yellow.
Congratulations on making one working one 😀 I've done similar and if you managed that while keeping the calibration then that's excellent - even impressive if you had to recalibrate after. At this point I've done motor swaps and other stuff on Citizen W1D drives to get 1 working one from 2 duds - always worth it.
The past few days things have settled down and I've been able to print a much more suitable Compact Flash card holder since I now have much more than 10, this design screws into the bottom of a wood shelf and uses VHB tape on the front to attach while keeping the space above fully usable. This design holds 25 cards and is the width limit of my printer - it sucked having to re-do it as well since it takes 4 hours to print and the first print I forgot to put in the tolerances so no cards could fit.
Previous designs I've done for a PCMCIA card holder were just 1 row holding six cards but they weren't staggered like this - the 45 degree angle means I can get to each row and column easily, it prints very nicely too since no overhangs.
The very dirty Tecra 750DVD is all cleaned up now and apart from the smashed LCD panel (which I have a spare for), it's working great. The DVD drive didn't want to read discs though and it's very unique to this laptop model. I spent some hours with the drive in bits and eventually got it functioning by reflowing the flex cable connectors for the drive sled and laser mechanism. A USB > laptop IDE converter + a bench PSU were a great help in getting it working.
Also this laptop got upgraded to a CF card instead of the 5GB hard drive which was making some crazy clunking noises and the bearing noise drove me crazy. So much nicer with general operation now being silent.
I'm glad I was able to get the DVD drive working - it's a custom physical size so a replacement drive just isn't an option, this laptop has an integrated DVD decoder so dropping to a CD-ROM drive would be a real loss.
Actually using USB-C Power Delivery is such a huge convenience - cables that can request their specific voltage mean I don't have to use the bench PSU to power every single thing any more:
Not pictured but I even made a USB-C Power Delivery 'dongle' for my Toshiba Portege 3000 series and Libretto 100CT laptops - they use a really tough to source tiny 2-pin connector and I hacked one up by melting a suitably sized JST connector. Now my Portege laptops are portable again even with dud batteries since power banks can source enough power to pretend to be the DC power brick 😀
