First post, by demiurge
So I am a new member of the retrocomputing scene and my collection was just sound and vga cards until I needed some test benches.
I bought this ABIT AB-PG5 because it is the only system built for an obscure VGA card.
The system came with an MMX Pentium which uses a 3.3V core voltage. However, the motherboard only lists a 3.4V option and a 3.5V option.
I know it is it within 3.3V±5% below 3.465V is this intended for this motherboard?
AFAIK there were no 3.4V CPU made. Does the extra voltage degrade the chip?
This motherboard clearly had an intent of having a lower voltage, but why wouldn't there be a 3.3V option instead? It doesn't make sense that there were only for overclocking options for 3.3V chips.
I have been looking for a copy of the manual but the internet doesn't have it indexed and the ABIT FTP never had it. So if someone could dig that up for me that would be great.
Reply 1 of 7, by majestyk
Are you sure it´s a Pentium MMX 3.3V single voltage CPU? (I cannot remember having seen one.)
MMX usually are 2.8V core voltage, so if this is the case, you would indeed overvolt it @ 3.4V.
If it´s a regular - non MMX - 3.3V Pentium, the 3% "overvolting" at 3.4V will not hurt it.
Reply 2 of 7, by mkarcher
majestyk wrote on 2024-01-21, 07:30:
Also, the MMX pentiums are "split voltage", with a "core voltage" of 2.7 or 2.8V, and an "I/O voltage" to communicate to the mainboard. The I/O voltage of the MMX processors is the same as the core voltage of the classic Pentium processors, and may be 3.3V to 3.6V (some processors required 3.45V to 3.6V). The jumper that configures the single voltage of Pentium processors usually also configures the I/O voltage of Pentium MMX processors, and supplying 3.4 volts at that place is perfectly fine.
Reply 3 of 7, by dionb
This board doesn't support split voltage, so that 3.4V/3.5V is fed to the core too.
The only Pentium MMX that supports that is the Overdrive. If this is a non-overdrive MMC it's being overvolted by at least 0.6V, which is over 20% and so and way out of spec.
The P55C core is so robust it (pretty uniquely) can survive that for a while, but it's not good and will shorten the lifespan of the chip, particularly if cooling isn't optimal.
Reply 4 of 7, by demiurge
Thanks all for the replies
That is something that was a bit confusing to me on the meaning of split voltage. The board has only two voltage options for "CPU" and I have no idea if that is just I/O voltage
dionb wrote on 2024-01-21, 10:39:
Sounds like I really need to get a 3.5 V CPU in there sooner than later because 3.3V and split voltage seems to be unsupported.
So this is the CPU https://www.cpu-world.com/sspec/SL/SL27K.html
Reply 5 of 7, by watson
Yeah, that CPU is slowly being cooked at 3.4 V.
Any "regular" Pentium (non-MMX) should be a good replacement.
Reply 6 of 7, by dionb
demiurge wrote on 2024-01-21, 13:28:
There's a huge difference between running 3.3V spec CPU at 3.4V (no problem, in spec and actually done quite frequently to improve stability) and running 2.8V spec CPU at 3.4V (long slow toast). Just stick in a 3.3V CPU, it will be fine.
That is a 2.8V CPU requiring split voltage. Don't run that at 3.4V (or 3.3V) for a long time. Any non-MMX Pentium will be fine on this board.
Reply 7 of 7, by demiurge
dionb wrote on 2024-01-22, 17:18:
I'm going to go Cyrix just for fun.
