Reply 360 of 411, by Gmlb256
Not surprising given that VIA C3 CPUs tend to focus more on low power consumption. Nehemiah is comparable to a Coppermine Pentium III at 700-800 MHz and the idea of using them isn't for absolute performance but flexibility when dealing with speed-sensitive software.
Reply 361 of 411, by cryptowhale
Is it possible to add 3/2 multiplier for Pentium Pro?
Reply 362 of 411, by DenizOezmen
cryptowhale wrote on 2024-01-17, 18:16:
In theory, the BIOS already supports the 3/2 multiplier, though the item is hidden in the dropdown. If the CPU is recognized as unlocked (i.e. you get to choose the multiplier in setup), it might be as easy as unhiding the item. Would you like to test this on a specific board?
Reply 363 of 411, by overdrive333
Thx.
Reply 364 of 411, by dm-
i have a CUV4X-D mobo with ViA chipset.
a few notes after i installed 1010 patched version.
1. is there any chance to fix a PCI latency issue with bios mod?
2. 2x memory interleave mode enabled by default. can we mod it to 4x w/o using windows path? ( +100mb/sec to ram bandwidth)
Reply 365 of 411, by DenizOezmen
overdrive333 wrote on 2024-01-27, 10:50:
Thx.
Nice. 😀
dm- wrote on 2024-02-01, 05:14:
Depends. There seem to be dozens of settings/patches around to improve PCI performance on VIA chipsets. Do you have any specific setting in mind?
Might be possible. I've added a test BIOS to this post, which -- assuming I have found the right place -- should set the lowest two bits of northbridge registers 0x64-0x67 to "10" to enable 4-way interleave.
(No idea what happens if you try to use this with SDRAM modules that don't have 4 banks, though.)
Some sources say the in-order queue depth should be set to 4 along with the interleave to enable full performance. I haven't checked what value the CUV4X-D sets.
Reply 366 of 411, by dm-
1. a PCI latency patch from George Breeze.
i have a couple of PCI graphics cards and they just won't work properly until i install George Breeze patch for PCI latency. Of cource it is not possible to use patch in case of Linux OS.
2. Tnx. I'll try this version!
Reply 367 of 411, by DenizOezmen
dm- wrote on 2024-02-02, 04:35:
Ah, I see. According to the history, the patch changes various settings depending on the chipset; not sure if all of them are documented. Unfortunately, I won't have time to go through all of them. If you know of a certain setting that would help you, we can see whether it's feasible to mod the BIOS.
Reply 368 of 411, by Sispik
ASUS CUBX-L (rev 1.01) update successful, ty!
Does anyone remember if on-board Trend ChipawayVirus was toggleable? I can't find the option to turn it off, I think there was with ASUS 1007.A (initial release) BIOS.
But I have two 440BX boards, I might confuse them. Plus its not a real issue, not enough to downgrade and see myself
Reply 369 of 411, by DenizOezmen
Sispik wrote on 2024-02-09, 00:04:
Glad to hear!
Should be "Boot" | "Boot Virus Detection".
Reply 370 of 411, by riplin
Hi, I know this is a long shot, but how hard would it be to add support for the Gigabyte GA-6BXD?
Reply 371 of 411, by y2k se
I previously modified the P2B 1014 Beta 003 BIOS to accept my 6B4 CPU ID Tualatin Celeron 1.4 without a warning. But, I successfully flashed the P2B (with hardware monitor) BIOS from 1014-003_20230728.zip in order to get proper power supply fan monitoring.
Tualatin Celeron 1.4 + Powerleap PL-IP3/T, ASUS P2B, 512 MB RAM, GeForce 4 Ti 4200, Voodoo2 SLI, AWE64, 32GB IDE SSD, Dell 2001FP
Reply 372 of 411, by DenizOezmen
riplin wrote on 2024-02-13, 23:57:
Hi, since this would be pretty much a new build, I won't have enough time to do a complete port in the near future. Is there anything specific you would like to try?
Reply 373 of 411, by riplin
DenizOezmen wrote on 2024-02-17, 12:23:
I was hoping for Tualatin support, but I managed to pick up a CUV4X-D for cheap that you already made a BIOS for, so I'll probably run some Coppermines in the GA-6BXD. 😀
Reply 374 of 411, by DenizOezmen
riplin wrote on 2024-02-17, 21:39:
Okay. 😀 You can still try the attached mod, if you like. There a no fancy changes, just a few tweaks to make the BIOS handle Tualatins like Coppermines. (At least in some obvious places.)
Reply 375 of 411, by riplin
DenizOezmen wrote on 2024-02-18, 13:10:
Awesome, thank you so much! 😁
Reply 376 of 411, by Gustl
Thank you
Your bios updates for the cubx l worked great with the award 2.21. Now I have a cosmetic question. Is it possible to change the white color of the boot screen from white to green when everything is running normally, similar to the old computer?
Reply 377 of 411, by Gustl
So the font
Reply 378 of 411, by DenizOezmen
Gustl wrote on 2024-02-19, 10:31:
Thank you
This is kind of possible, at least pretty easily for the short phase after VGA ROM init and before OS takes over. Don't know what would be necessary to influence other parts of the boot process.
(Though on a personal note -- it looks kind of weird to me.)
Reply 379 of 411, by Gustl
A dream come true. THANKS
