Reply 51640 of 58806, by acl
Nothing fancy but I found this Asus V3400TNT (SDRAM). It'one of the few models that came out with an active cooling.
I never had a TNT "1". 10€ I hope I works.
The attachment IMG_20240201_211640.jpg is no longer available
Reply 51641 of 58806, by Karbist
I bought this DFI PB60-VB board from some recycler and the bios chip was missing so I ask him if he still has the chip and he said no but he was kind enough to ship the board with a bios chip from another board.
now I need to program it with correct bios file, replace the caps and wash the board, hopefully it'll work.
The attachment PB60-VB.jpg is no longer available
Reply 51642 of 58806, by ubiq
Took a chance on an "untested" Voodoo 2 auction because the price was right, and a localish seller (cheap shipping) and well:
The attachment IMG_0559.jpeg is no longer available
Hmm, ok, not the end of the worl...
The attachment IMG_0558.jpeg is no longer available
Oh. 🤦‍♂️
Was it shown in the original listing?
The attachment s-l1600.jpg is no longer available
Pretty much. Oh well, caveat emptor baybee!
Reply 51643 of 58806, by rkurbatov
Karbist wrote on 2024-02-01, 23:07:
How do they relate to DTK? All these Taiwanese companies were a real miracle - such a motor for the industry, inventing, stealing and faking at the same time - just like a modern China but probably somewhat more Creative (lol, pun intended).
Like, they were the same company or a group of companies? Because I often see them together. My first monitor was from DTK. And just recently I bought DFI memory expansion card DFI Rambank - and found the very same but named DTK Rambank.
486: ECS UM486 VLB, 256kb cache, i486 DX2/66, 8MB RAM, Trident TGUI9440AGi VLB 1MB, Pro Audio Spectrum 16, FDD 3.5, ZIP 100 ATA
PII: Asus P2B, Pentium II 400MHz, 512MB RAM, Trident 9750 AGP 4MB, Voodoo2 SLI, MonsterSound MX300
Reply 51644 of 58806, by rkurbatov
ubiq wrote on 2024-02-01, 23:14:
Oh. 🤦‍♂️
Better call Bits and Bolts. That's what he likes 😀
Reply 51645 of 58806, by acl
The BIOS chip needs to be of the same type as the original one.
If you have a board that share this type of BIOS you can hot-swap them to flash the "empty " BIOS.
(By booting with the working board. Once in DOS, removing the BIOS chip while the system is running and replacing it with the empty one. Flash the BIOS. Poweroff. Install the BIOSes back in their original motherboards. Voilà !)
I saved a SS7 board that way.
Reply 51646 of 58806, by rkurbatov
acl wrote on 2024-02-01, 23:19:
TL866 and you don't need these dangerous tricks, only the BIOS dump from retroweb.
And as for BIOS type - with DIP packages it's probably standard 512K chip that was used for quite a time since 386 to Pentiums and even P2.
Reply 51647 of 58806, by Karbist
The BIOS chip needs to be of the same type as the original one. If you have a board that share this type of BIOS you can hot-swa […]
It's a 256KB chip and I already hot flashed it, also dumped the bios image from it and chip was taken from ECS P4VMM2 board.
Reply 51648 of 58806, by Kahenraz
Took a chance on an "untested" Voodoo 2 auction because the price was right, and a localish seller (cheap shipping) and well.
Oh. 🤦‍♂️
Ouch! That's some impressive damage there. It might be possible to shave off a little bit of the plastic packing and reconnect those pins maybe.
Reply 51649 of 58806, by Trashbytes
Kahenraz wrote on 2024-02-02, 03:45:
Oh. 🤦‍♂️
Would be quicker to just remove that chip and replace it, plenty of donor cards out there.
Reply 51650 of 58806, by Kahenraz
You're not wrong. But he still need to source a second card at a reasonable cost. Even known-bad cards are selling at a premium. Add the cost of repair and shipping, it might be close to the cost of a working replacement.
Reply 51651 of 58806, by Trashbytes
Kahenraz wrote on 2024-02-02, 04:13:
Very True, still repairing that chip and reattaching the legs will require a fair amount of skill at micro soldering and microscope use, certainly not a repair for the inexperienced.
Reply 51652 of 58806, by H3nrik V!
Took a chance on an "untested" Voodoo 2 auction because the price was right, and a localish seller (cheap shipping) and well: IM […]
Oh. 🤦‍♂️
If you're a user on cpu-world.com there's NOS chips for sale here ...
https://www.cpu-world.com/forum/viewtopic.php … &highlight=3dfx
Reply 51653 of 58806, by appiah4
Shponglefan wrote on 2024-01-31, 16:30:
Picked up this MiroSOUND PCM 20 sound card.
Don't really know anything about it, but it looked unusual so I bought it.
Wow, that looks so nice!
Reply 51654 of 58806, by appiah4
Oh. 🤦‍♂️
'tis but a scratch..
Seriously, fixable..
Reply 51655 of 58806, by tauro
Oh. 🤦‍♂️
Ouch!
That can be fixed but you'll need a steady hand and patience.
Check the datasheet. If it gets too difficult, maybe there's some NC or redundant pins such as GND that could be left alone and increase your chances of getting it working.
Reply 51656 of 58806, by douglar
I saw a drive controller on Ebay at a low price and ordered it.
What showed up was still shrink wrapped.
The attachment Photo Feb 02 2024, 9 40 39 AM.jpg is no longer available
I want to play with it, but I also don't want to open it.
I'd almost rather get a dirty board to clean up than to remove shrink wrap.
Am I weird?
Reply 51657 of 58806, by BitWrangler
Nice score
douglar wrote on 2024-02-02, 14:51:
I feel you, it's kinda like feeling history frowning over your shoulder if you sully a nice one, but smiling if you take a lost cause and improve it in any way.
Reply 51658 of 58806, by rkurbatov
Am I weird?
Lol. You are not alone. That's why I prefer buying separate items. Hunting for drivers, investigation is the part of the game. And here you have everything clean, working and having all you need to start. Though unpacking something new is also somewhat interesting.
My Tekram VLB IDE controller also lies somewhere waiting for 5x86 Novell Netware "server" build 😀 I had to find two identical drives for it and found three as a result.
Reply 51659 of 58806, by Kahenraz
I watched a YouTube video on how to setup a Novell NetWare sever once. It does not look pleasant.
