Reply 51780 of 58399, by devius
BitWrangler wrote on 2024-02-13, 04:26:
MSI did a ti200 128MB too that I know of, got one, turns out 128MB wasn't really worth it until 2 gens later.
Also Chaintech A-G321.
Reply 51781 of 58399, by acl
I have a 256MB version of Matrox Parhelia. That's also an unusual amount for 2002
Reply 51782 of 58399, by Nexxen
acl wrote on 2024-02-13, 13:40:
Amount in line wih your avatar... for a clean and sharp image!
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 51783 of 58399, by acl
Nexxen wrote on 2024-02-13, 16:24:
Yes, even on three monitors !
I don't even know why i still use this avatar.
Some people (not here) even asked me if i was bald... well not really. I should have picked John Romero as an avatar if it was all about real life hair style.
Reply 51784 of 58399, by PC@LIVE
Purchased a batch of RAM today, of various capacities and speeds, I plan to use some of them on the 775 or AM2 PCs, I am currently working on an ABIT IP35 with E4600 @ 2400, a PC that I will use mainly for Office, it has 6GB of RAM that I would like to bring to 8 GB, using two of the 2 GB memories each, and removing the odd one.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 51785 of 58399, by Socket3
Got a couple of 21" CRT monitors yeasterday. One IBM P260 and one Dell 1230. That makes 3 21" CRT displays I've managed to get my hands on so far.
The attachment WhatsApp Image 2024-02-12 at 15.24.57_abcd081b.jpg is no longer available
The attachment WhatsApp Image 2024-02-12 at 15.24.32_39f8f6ac.jpg is no longer available
Both monitors are pretty scuffed up on the sides, but the front bezels, buttons and glass is OK, and both work perfectly. Nice bright picture and good geometry. The IBM P260 completes my Thinkcenter setup quite nicely. I remember I used to have one of these 21" IBM's back in 2005, along with a beige 21" Eizo.
The attachment WhatsApp Image 2024-02-12 at 20.59.08_477221c5.jpg is no longer available
One interesting thing about the IBM is that it has a DVI connector - I've tried hooking it up to my daily driver via a DVI to HDMI adapter, but it didn't work. I really wish it did tough, since there's lots of boomer shooters and modern ports of older games that would have looked stellar on the P260. I guess it either has a very early implementation of DVI, or it's just not playing nice with my video card.
The attachment WhatsApp Image 2024-02-12 at 15.24.32_45ec0609.jpg is no longer available
Reply 51786 of 58399, by Vynix
The P260's DVI port is a bit odd, it's not a fully wired DVI-D port but rather, a DVI-A port.
As far as I know only NEC made CRT monitors with DVI-D ports, but those aren't very common.
Reply 51787 of 58399, by PcBytes
My recent retro HDD haul for yesterday:
- Seagate Medalist 4321 - working, neat shape! One of Seagate's better drives IMO.
- Quantum Fireball Plus AS 20GB - also working and as a bonus, has 98SE installed already, and its contents are a time capsule.
- Quantum Fireball 630AT 630MB - might be bad as only 310MB managed to get tested. I might have a chance fixing it with either Spinrite or DiskGenius.
- Fujitsu MPE3102AT - dead apparently. Produces garbled text during POST and won't seek properly.
- Fujitsu MPB3021AT - works
- 2x Quantum Bigfoot CY 2160AT - one is dead with unreadable sectors, the other is absolutely fine (managed to partition and format just fine)
Reply 51788 of 58399, by pete8475
Socket3 wrote on 2024-02-13, 22:52:
I had the beige version of that IBM monitor many years ago!
Mine came with a cable that was DVI on one end and VGA on the other, with that conncted to a PC and another PC on the other VGA port you could switch between inputs on the monitor.
Reply 51789 of 58399, by Minutemanqvs
These last weeks I bought all kinds of adapters and readers just because I'm always frustrated when I don't have the right thing, and now is a time when they are cheap and still available. That is CF > IDE, SATA > IDE, USB-A to USB-C, USB Floppy, USB CF/SD reader, Molex to SATA power etc etc...I remember 20 years ago when some adapters were everywhere and now very hard to find. So I will not make the same error twice.
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
Reply 51790 of 58399, by weedeewee
Minutemanqvs wrote on 2024-02-14, 10:06:
I hope you got an USB floppy which can do both 720K & 1M4 😀
Do not ask Why !
Reply 51791 of 58399, by Kahenraz
weedeewee wrote on 2024-02-14, 15:40:
Are not all USB floppy drives capable of reading and writing 720K disks?
Reply 51792 of 58399, by A001
PcBytes wrote on 2024-02-14, 00:03:
I find this model is an incredibly quiet drive for its time period. I was testing several old drives yesterday and this one was among them.
Reply 51793 of 58399, by PC@LIVE
Purchased these two motherboards, the first a Soyo VX with 256 KB of cache, it is a board with an Intel chipset, and could it perhaps support dual voltage CPUs?
The other is an ASUS Slot1, honestly I didn't understand what it was, I was thinking of the usual cheap card, and the missing AGP slot was a problem for me, then by chance I managed to understand that it wasn't that bad, the chipset should be a BX , and I believe the model is P2B98-XV, in view of all this, I have re-evaluated it and I hope to have it in my hands soon.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 51794 of 58399, by H3nrik V!
pete8475 wrote on 2024-02-14, 00:40:
That's so perfect for a setup with Voodoo(2), using one input for a good 2D VGA card (Matrox <3) and one input for the Voodoo, thus eliminating the need for that blur-inducing pass-through cable 😁
Reply 51795 of 58399, by kaposzta
I've received two package today with some interesting video/sound cards.
Package 1 ($30):
- Creative Labs PhoneBlaster (CT3120) --> unfortunately, the upper right corner is broken off, sound card part might still be working though
- Cirrus Logic Laguna 3D (Chaintech) --> perfect condition, tested and working
Package 2 ($90): everything is untested and extremely dirty 😀
- a weird, unidentified 8 bit ISA video card from 1987 with DB9 connector, no RCA connector, two crystals, no Motorola 6845 chip but with Intel A82786 (SX117) graphic co-processor (see picture)
- Trident TVGA9000B
- Matrox G100
- ELSA Winner 1000/T2D (S3 Trio64V2/DX) --> nice addition to my ELSA collection
- Diamond Viper V550
- Asus V3000ZX --> finally I have a Riva 128ZX! 😀
- Spea V7-Mirage P-64 (S3 Vision864) PCI --> already had the VLB version
- Ati Mach64 GX --> my first Mac64 GX
- DataExpert ExpertColor S3 Virge GX2
- Sapphire X1550 Ati Radeon X1550 AGP --> too modern for me, but still an interesting card, as I cannot find the same version neither in Google nor on eBay
- ASUS V7100PRO/64M
Anyone can identify the 8 bit ISA card?
Reply 51796 of 58399, by Trashbytes
kaposzta wrote on 2024-02-14, 22:24:
I've received two package today with some interesting video/sound cards. […]
Package 1 ($30):
- Trident TVGA9000B
- Matrox G100
- ASUS V7100PRO/64M
What ever that card is (CGA/Mono/Hercules) with the window exposed on that EPROM its certainly not going to work, one for the display shelf or spares box perhaps unless you can identify the card and source a EPROM dump.
Reply 51797 of 58399, by kaposzta
Trashbytes wrote on 2024-02-14, 22:50:
Package 1 ($30):
- Trident TVGA9000B
- Matrox G100
- ASUS V7100PRO/64M
Yeah, it's definitely not going to work, the EPROM might have been exposed to sunlight for years... Another issue is that the graphic co-processor is missing a leg, good news is that it's still in the socket 😀
I don't think it's CGA, as there are crystals on the card, and I'm not sure if it's an MDA or Hercules card either, as there is no Motorola 6845 chip on it. And probably it's not an EGA, as it looks a bit basic for an EGA card.
Reply 51798 of 58399, by Trashbytes
kaposzta wrote on 2024-02-14, 23:04:
Package 1 ($30):
- Trident TVGA9000B
- Matrox G100
- ASUS V7100PRO/64M
Could be one of them proprietary ones from an early IBM machine, its made in the US in 87 which puts it around the VGA era, might not be a display card.
Hrmm
The MB7142H IC is a Fujitsu TTL PROM, so its a display card of some kind, im guessing a proprietary job.
Reply 51799 of 58399, by kaposzta
Trashbytes wrote on 2024-02-14, 23:09:
Could be one of them proprietary ones from an early IBM machine, its made in the US in 87 which puts it around the VGA era, migh […]
Hrmm
Yes, this card is a mystery... I planning to send this card to a collector friend, he might be able to get some information out of that EPROM.
