Y2K builds
First post, by fillosaurus
I managed to build the wet dreams computer of 2000.
For more important stuff, I stuck with parts from 2000. Here it goes:
Second generation slot A Athlon@700, ASUS K7M motherboard, 256 MB SDRAM, ATI Radeon 7500, SB Live! 5.1, 40 GB WD HDD.
Parts I cheated:
A VIA USB 2.0 card, newer (2003) DVD drive and much newer case (an ASUS Vento TA 861, bought new in 2007); because most of 2000 cases were butt ugly and had no front USB.
Y2K box: AMD Athlon K75 (second generation slot A)@700, ASUS K7M motherboard, 256 MB SDRAM, ATI Radeon 7500+2xVoodoo2 in SLI, SB Live! 5.1, VIA USB 2.0 PCI card, 40 GB Seagate HDD.
WIP: external midi module based on NEC wavetable (Yamaha clone)
Reply 1 of 17, by nd22
Great build! Some pictures please.
I don't think Radeon 7500 is a card from 2000, rather from 2001! Also I think the CPU and the board, while very good , are actually from 1999 - that makes your build the 1999 dream machine.
I also got a Slot A build that I hope to finish some day: the same Athlon 700, 512mb of SDRAM, geforce 256DDR, Abit KA7 motherboard.
Reply 2 of 17, by Cypher321
Which OS did you go with? If it's not Windows ME I'll be very disappointed 😉
Reply 3 of 17, by fillosaurus
nd22 wrote on 2024-02-19, 08:35:
CPU was launched in november 1999, so it counts for 2000 (was commercially available then). Radeon is from 2000, and ASUS K7M was one of the first mainboards for Athlons. As for ubiquituous SB Live! 5.1, I have just 1 different soundcard with same abilities, a less known Philips PSC703, but was marketed later, '02 or '03. If Philips improved the drivers, that chip would have been a SB killer. Unfortunately, it was a half ass attempt for them.
And to say it in our language... Pula mea...
Reply 4 of 17, by fillosaurus
Cypher321 wrote on 2024-02-19, 08:46:
Neah, went with evergreen 98SE. Never liked ME, installed it once, tried&tested it, after a week I went back to 98.
Reply 5 of 17, by fillosaurus
CPU is second generation of Athlon slot A, I checked its S/N.
Now that I am almost finished with this, I will focus on my next build, a Chaintech motherboard socket 370 with a Celeron CPU and onboard sound ESS Solo. Think I will put a Voodoo on this.
Reply 6 of 17, by fillosaurus
As you wish...
Reply 7 of 17, by chinny22
Case should be beige but this one has a "semi accurate" AMD Athlon sticker... maybe the II stands for second gen?
Not that I can talk nothing I own is period correct.
I like my Slot A, its not as stable as the Slot 1 but it' not as common either.
Reply 8 of 17, by fillosaurus
chinny22 wrote on 2024-02-19, 22:37:
It was my main case for many years and the sticker is from an actual Athlon II tri-core, which is a 64bit K10 socket AM3 CPU that I had for some years since 2012 before I replaced it with an AMD FX6300 CPU, at the same time that I replaced the case with a Zalman Z9 U3 with low positioned power supply, side access to HDDs, CPU temp display and 4 front USB (2 USB2, 2 USB3). That case has an AMD FX sticker, even if inside is now an Intel i5 7500, Gigabyte Gaming 3 Intel H270 motherboard.
I always customize my computers, last factory/shop built one was a Compaq Prosignia 300 which was meant as a cheap server for small business; CPU (In my case a Pentium 90) and 16 MB soldered RAM were on a separate board, and had 6 72pin FPM/EDO RAM slots on same board, onboard Cirrus Logic 5428 512kb RAM video, onboard SCSI2 controller, 2 PCI and 5 or 6 EISA slots. No onboard IDE, so for my IDE CD-ROM I used the IDE port of my then soundcard, ESS1868. Also used an external jukebox NEC SCSI CD-ROM with a 7 disk capacity.
When I said second generation slot A K7, I meant it; first generation was 250nm, second was 180nm. They shrunk the fabrication. Third generation aka "Thunderbird" was in slot and socket A versions, then followed the Athlon XP, socket A only.
Reply 9 of 17, by leileilol
fillosaurus wrote on 2024-02-19, 13:05:
Radeon is from 2000
Specifically Radeon 7200 is the 2000 Radeon. 7500 is a big improved iteration from the year after, ditto for the budget-minded 7000 iteration.
Debian's fucked
Reply 10 of 17, by fillosaurus
leileilol wrote on 2024-02-20, 04:41:
Radeon is from 2000
AFAIK, 7500 is just a process reduction of first Radeon, from 2000, so it counts for 2000, even if it was launched in 2001. Same with 99/00 Athlons. And 7500 became a budget part when 8xxx series appeared, until then was king of the hill. Maybe not so fast as a GeForce 2 GTS, but not far behind it.
Reply 11 of 17, by fillosaurus
Tested the system with some very demanding games from 2000-2003. It works well with any Quake 3 engine game, old Unreal flies, yet to try Dungeon siege.
Reply 12 of 17, by fillosaurus
Phuc... Tried again Unreal Gold. IMO, that game needs a Voodoo to really shine, any other 3D card is bantha poodoo. So, I will put 2xVoodoo2 in SLI in the system.
Reply 13 of 17, by leileilol
fillosaurus wrote on 2024-02-20, 06:14:
It's at least 100MHz higher and can beat the Geforce2 Ultra at a bunch of things...
Debian's fucked
Reply 14 of 17, by DarthSun
Good configuration! 😀 This era is beautiful.
I also built on K7M for SlotA. A forgotten piece, it traveled through time on a wholesaler's shelf and came to me newly.
The attachment k7m.jpg is no longer available
Asus K7M motherboard
Athlon 800MHz Pluto CPU
1x256MB+2x128MB SDRAM 133MHz CL3@100MHz CL2
Radeon 9800 video card
SB Live SB0060 + GravisClassic sound cards
Micronet RTL8139D network card
MaxtorDX540 20GB + Samsung SV0844D 8.4GB drives
LG GCE8523B CDRW
1.44 FDD
Codegen 6039L-G8 SP ATX case + 350W FSP power supply
Win98SE and DOS7.1/6.22 operating systems
The attachment saopen.jpg is no longer available
The attachment safront.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 15 of 17, by fillosaurus
DarthSun wrote on 2024-02-22, 18:27:
Good configuration! :-) This era is beautiful. […]
LG GCE8523B CDRW
1.44 FDD
I received mine from ex-brother in law (his wife and my ex are sisters). Mobo and CPU. Rest of the stuff I had hanging around.
Reply 16 of 17, by DarthSun
fillosaurus wrote on 2024-03-30, 09:40:
LG GCE8523B CDRW
1.44 FDD
It is best to come for the retro for free, and I got a lot of hardware on myself.
Reply 17 of 17, by fillosaurus
I switched to Intel and did some work with 2 BX based boards; some of the best. Abit BH6 and ASUS P2B. On Abit none of my slotket adapters work, so the fastest CPU which works on it is a slot 1 Pentium III Coppermine 600E.
On P2B my slotket Soltek (say that fast 3 times) works perfectly, put on a P III 1GHz, mobo has a setting for 133 FSB and 33 PCI, so no overclocking for AGP and PCI bus. The CPU cooler I choose blows air laterally onto video card (GF4 MX). Need to dismantle and clean the insides of the fan, is quite noisy; Nothing that isopropylic alcohol and a spray of WD40 won't cure.
