First post, by dfaber1
Hello,
I want to reprogram a Bios chip with my TL866II Plus, but I can't seem to fin the chip model in the list. Can anyone tel me what I should use to reprogram this Bios?
Reply 1 of 6, by Nexxen
dfaber1 wrote on 2024-02-26, 01:29:
Hello,
Remove the sticker.
BTW, board's name would help.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 2 of 6, by dfaber1
Never mind, I'm an idiot. I found it by removing the sticker
Thanks.
Reply 3 of 6, by zwrr
If the chip is very old and you want to protect that fragile sticker, or you have encountered a fake ROM chip, you can try this method to determine the model of the ROM chip.
1. Select a ROM model in Xgpro at will, for example, select AT27C256, and then start reading the ROM chip, then the software will report an error, and at the same time will display Check ID is: 0x xx xx.
The attachment Xgpro-1.jpg is no longer available
2. Find the InfoIC2Plus.dll file in the Xgpro installation directory, and open the file in hexadecimal form with UltraEdit, EmEditor, and WinHex.
The attachment Xgpro-2.jpg is no longer available
3. Look for that Check ID in the file, you may find a lot, continue to search patiently, you will see some chip models.
The attachment Xgpro-3.jpg is no longer available
4. What is the chip in the example?
The attachment Xgpro-4.jpg is no longer available
SBC1: Cyrix 5x86-120, HS-5x86HVGA, 16MB EDO, GD54M30, SB Pro II, HardMPU-wt
SBC2: VIA C3-800, PCISA-C800, 128MB SDRAM, Savage4 Pro, SB AWE64 Gold
SBC3: Tualatin-S 1.4G, PCI-6872, 256MB SDRAM, FX5200 PCI, Voodoo2 SLI, SB Live
Reply 6 of 6, by dfaber1
Thank you 😀
