First post, by popcalent
Hi, all.
I bought a PC104 card, it's a 386 at 40MHz. The card is an ICOP 6052V. I'm having a number of issues with it.
First of all, I couldn't find a VGA or keyboard adapter so I had to make my own. The screen looks shifted to the right even when I change the X position on the monitor to the opposite maximum. I assume there are no issues with the cable I made or else there would be no image at all.
I'm trying to connect a floppy drive to the board. But when the floppy drive is connected, the board doesn't seem to start. The board is powered with a 5V@3A power supply, and the floppy drive with a separate 5V@2A/12V@2A power supply. So it's not a problem of not enough amps. The cables are well connected because there's only one way they can go. The drive works on other computers. If I disconnect the floppy drive while the board is powered, the image appears on the monitor and it turns out it powered up but it didn't send any signal to the screen. However, the keyboard doesn't work at this point. I have to turn it off and let it cool down for a minute or two for the keyboard to work again...
Is there anything that I'm missing here or is this a faulty board? Thanks!
