First post, by RoozerXC
Over the past few months I've been trying to tackle a problem that's been causing me lots of headaches. I have tried scouring the Internet and VOGONS (hello!) for a solution, but nothing worked really. I do not know if this is the right forum to post issues like this but I'm hoping that I could get some solutions from this site. I do not have any picture attachments at the moment because my phone got repaired, and I couldn't take pictures with my camera app anymore due to a myriad of issues with the refresh rate, touchscreen and whatnot
Anyway, when I boot up the computer the temps skyrocket to 131 C, even on BIOS so the CPU is literally getting toasted to death as I turn on the machine. Since this is a COMPAQ Presario SR1820NX desktop that was given to me by a relative's boyfriend, I do not have any options to control the voltage or clock speeds on this machine. I can check the motherboard's revision, but since I'm running out of time I'll just check the motherboard revision later (tomorrow hopefully). It's a Socket 939 board
When I disassemble the machine and remove the CPU from the heatsink, it looks like it's barely making any contact despite the entire CPU being covered with the thermal paste, and most of the thermal paste just dried away quickly. I have made sure that I latched the heatsink tightly so that it makes proper contact with the CPU
I did try a couple of things
- cleaning all of the dust so it has better airflow
- repaste the CPU and heatsink together
- spread the paste on the CPU evenly with a spatula so it covers the entire thing
- try different thermal paste (recently I ordered Arctic MX-4)
I have here the following specs, although I haven't been able to install other drivers (besides the GPU) because of this issue
- Bestec 300W ATX power supply
- AMD Athlon 64 3700+ @ 2.2 GHz
- 1GB / 1x1GB @ 400MHz DDR1
- PNY NVIDIA GeForce 6600 GT (PCI Express)
- Creative Labs Sound Blaster Live! CT4830
- Seagate Barracuda 7200.7 160GB HDD
I also tried Arctic MX-6 a while back but I just simply wasted it out of frustration, only to get above 80 C on idle after POST and this is even before booting 98 SE. I really don't want to be wasting any more money and thermal paste fixing this issue, and I'm certainly doubtful that replacing the heatsink and everything else would even fix anything. I was considering getting thermal pads instead since I've seen PCL (phil) use them for all of his machines, but again I'm very doubtful that it would make the difference at all and would only make the CPU temps skyrocket even further
Has anyone ever experienced the same overheating issue as I have? Is this just a user error and I'm applying thermal paste wrong all the time? Is it just a bad PSU (even though I have never experienced any shorts), or simply a bad heatsink? It's just confusing and it's a pain in the ass to have to repaste every time, only to get even worse temps. This project has gotten extremely messy for me these past couple of weeks
Reply 1 of 35, by mockingbird
RoozerXC wrote on 2024-03-07, 00:02:
<snip>
You need to delid the CPU and then apply some good paste between the die and the heatspreader... Yes, the TIM does not age well and AMD did not solder the core to the heatspreader, like they should have done.
You can then place the heatspreader back on, but make certain it's put back on correctly.
There's also a risk of breaking off an SMD component when you insert the flexible razorblade to break the silicone bond between the heatspreader and the PCB. This happened to me and I had to do microsurgery to get the tiny resistor network soldered back in its place.
I ultimately used two thin copper heatspreaders (with paste applied between each layer) and went for a direct die cooling approach because I found that getting the heatspreader back on right was finicky.
anyways, good luck
(Decommissioned:)
Reply 2 of 35, by kingcake
If the paste pattern shows improper contact, then nothing else is going to fix that.
Is this the correct Compaq heatsink? Did this machine originally use some kind of shim or thermal pad?
If the HSF is not making contact delidding will only make that worse.
Reply 3 of 35, by The Serpent Rider
All really old Athlon64 CPUs (pre-AM2) have a thermal paste under the IHS. Delid and reapply fresh paste (or liquid metal).
Reply 4 of 35, by kingcake
The Serpent Rider wrote on 2024-03-07, 00:35:
He said the heatsink is not making proper contact. Delidding won't fix that.
Reply 5 of 35, by Repo Man11
Socket 939 and AM2 (and later) are somewhat interchangeable, but not completely. I've tried AM2 coolers that would not properly fit a 939 bracket (couldn't make proper contact with the CPU), and one AM2 cooler I used made me realize that they changed the mounting bracket between 939 and AM2. The AM2 bracket uses four screws to secure it rather than the two used with 939. The four screw bracket is more rigid, so the HSF's clamping mechanism has less travel - this means that it doesn't clamp as securely as one made for the 939 bracket. Since the AM2 cooler was copper with heatpipes (made for a 6000+) I wanted to use it; but the 939 motherboard came with flexible push pin retainers and a plastic back plate. So I bought a 939 bracket that was secured with screws and a metal back plate.
Reply 6 of 35, by mockingbird
Fixed... There are many "post-AM2" that also use the thermal paste under the IHS.
(Decommissioned:)
Reply 7 of 35, by RoozerXC
kingcake wrote on 2024-03-07, 00:24:
I have literally no idea, it's just some random heatsink that this machine came with when I first picked it up. It never came with a thermal pad or some shims of any kind
Edit: there's also no model number or manufacturer name too
big chef - smilin' cowboy :)
Main gaming pc: GTX 1050 Ti, i7-2600, 32 GB RAM
Retro pc: 6600 GT PCI-E, Athlon 64 3700+, SB Live, 1 GB RAM
Other pc: GTX 660, i5-760, 16 GB RAM
nothing much here
Reply 8 of 35, by RoozerXC
mockingbird wrote on 2024-03-07, 00:23:
You need to delid the CPU and then apply some good paste between the die and the heatspreader... Yes, the TIM does not age well […]
<snip>
anyways, good luck
The same issues apply to an older 3400+ that the machine originally came with too. I had purchased an AMD Athlon 3700+ as an upgrade on eBay a little while ago and I can't be assed to delid it with a razor blade since I would risk cutting myself, and due to my mental state I feel very uneasy with blades. Perhaps a delid would make a difference but I'm not risking it
nothing much here
Reply 9 of 35, by RoozerXC
Repo Man11 wrote on 2024-03-07, 00:38:
Only difference is the heatsink has 2 metal latches, not screws (if you know what I mean basically). There are no screws involved to put the heatsink in place and/or to remove it from the CPU
nothing much here
Reply 10 of 35, by Repo Man11
The bracket in question. As I stated before, the HSF mounting bracket for Socket 939 isn't as rigid, so the HSFs for 939 have a longer throw on the clamping mechanism to make sure there is enough clamping force on the CPU. AM2 → have a shorter throw, which can be an issue. And some AM2 → HSFs have fins which will clear the bracket for an AM2 CPU, but will interfere with a Socket 939 bracket, which seems to be the issue that you have.
Reply 11 of 35, by The Serpent Rider
Which has nothing to do with my statement.
Reply 12 of 35, by RoozerXC
Repo Man11 wrote on 2024-03-07, 01:42:
Ahhh right. My frustration sometimes makes me mix things up and I get sidetracked a little bit so please excuse me
To my knowledge I don't have an AM2 bracket or heatsink at least as far as I know, and I'm still considering other solutions than just delidding or anything that might seem very hacky or risky (or could even cause injuries and additional damages). What im thinking is to maybe get a better 939 heatsink and bracket, but im not exactly sure what kind i would get in order to get stable temps again, since the OEM heatsink that came with this machine is probably subpar and terrible for the course given my recent "experiences"
nothing much here
Reply 13 of 35, by mockingbird
RoozerXC wrote on 2024-03-07, 01:30:
This post conjured up this image in my mind, for some reason:
427.01 KiB
(Decommissioned:)
Reply 14 of 35, by nhattu1986
To test if the heatsink made good contact with cpu, you can do this simple test.
put a bean size pea size blob of thermal paste at the center of cpu. prefer the soft cheap paste like GD900 or mx4
clean the heatsink contact area, put the heatsink on, leave it 1 minute for the paste to spread then remove the heatsink.
if heatsink made good contact, the paste should spread thin evenly and should almost cover the IHS area.
if heatsink does not made good contact or there are gap, you will see a thick paste and it not spread out much.
#EDIT: change the size from bean to pea
Reply 15 of 35, by Repo Man11
RoozerXC wrote on 2024-03-07, 03:04:
You cannot have an AM2 bracket because they are only on Am2 motherboards and will not fit on 939 because they have four mounting screws rather than two. But you might have an AM2 heatsink, especially since some of them will not fit properly when used with a Socket 939 mounting bracket.
You ought to see an impression like this on the heatsink after you have mounted it and clamped it down; the thermal grease should be uniformly thin across the contact area. If it doesn't look like this, you need to investigate why it isn't making proper contact - most likely reason is some interference between cooling fins and the plastic mounting bracket.
Reply 16 of 35, by kingcake
It might help to post some pics of the CPU in the socket and the bottom of the heatsink assembly.
Also agree to do a spread test. But "bean size" is way too much. Do a pea. Using too much paste will give a false result because it will look like you have contact when you really don't.
Reply 17 of 35, by RoozerXC
kingcake wrote on 2024-03-07, 03:34:
Yeah, i was trying to use different patterns on the CPU but they all ended up being very messy to work with. I will try repasting it tomorrow since I'm taking a break from working on the machine enough times, and having me pull my hair out a lot
And sorry if i never had any pictures. I'll try to borrow a relative's phone to take some pictures of the CPU and the heatsink assembly as well since my phone is unusable atm
nothing much here
Reply 18 of 35, by RoozerXC
mockingbird wrote on 2024-03-07, 03:15:
LMFAOOOOOOOO good one 🤣 I was actually being serious but that made me giggle a bit so it cheered me up a little, sorry if this seems to be getting off topic but I found that funny
nothing much here
Reply 19 of 35, by momaka
If you're getting the overheating issue with both the original (3400+) CPU and the new (3700+) one, I suspect the issue is more likely to be that the heatsink is not seated properly. Of course, it could also be a number of other things too, like the motherboard sensor is not reading the CPU temperature correctly. Or perhaps both CPUs really do have dried thermal paste under the heat spreader (though I find that to be more unlikely, as I have quite a few s939 CPUs and have not run into this issue yet.)
So let's start in order.
To easily rule out that the heatsink contact is not an issue, just remove the mounting bracket from the motherboard and put the heatsink directly over the CPU. This, of course, would only work if you lie the PC down on its side so that the motherboard is horizontally flat so the heatsink won't fall or slide off.
And here's a PRO tip: thermal paste / compound should only be changed IF it's too dry to spread or has too much debris / foreign matter (like dust or hair) contaminating it.
If you've just applied fresh thermal compound on a CPU and it doesn't work or you need to swap that CPU for whatever reason, don't junk / discard the thermal paste from it. Take a CLEAN credit card, sharp-ish spatula (plastic preferable), or some similar "tool" (no razor blades I suppose, if you don't like them 😁 ) and scoop the "old" compound from the CPU. The put on the new CPU and spread. If it's not enough, add a bit more fresh compound. That's all!
This will save you from wasting quite a bit of thermal compound.
I have plenty of CPUs and GPU's done with such "recycled" compound and have never had overheating issues.
The only way thermal compound will dry out is if the device is allowed to reach high temperatures (be it due to poor cooling from a clogged heatsink / poor airflow or a heatsink that is not adequate for the job.)
Anyways, back to regular scheduling...
If you tried the above (running the CPU without a the mounting bracket on the motherboard and only have the heatsink on top of the CPU) and you still get high temperatures with both CPUs, then perhaps the mounting bracket wasn't the issue. Which moves us onto test #2: try some different thermal monitor apps like HWInfo, OCCT, and SpeedFan to see what kind of temperatures they show with the CPU idling on desktop. Post some screenshots, if possible. Some motherboards have "cooky" sensors that may show bogus temperatures (and voltages.) Hopefully this can tell us if that's really so.
If not, then perhaps you really did get the short end of the stick with both CPUs and both just need de-lidding and applying fresh thermal compound under the IHS. But let's see after you do the above two tests first.
