fsinan wrote on 2024-03-17, 09:22:
CoffeeOne wrote on 2024-03-16, 19:49:You give only very little information, but I try once more.
You wrote an AMD 4x86DX4 works at 100MHz.
What is the exact model of […]
fsinan wrote on 2024-03-15, 14:32:
tested and controlled with different benchmarks and programs.
What is the exact model of the AMD? I mean what is printed on it.
A486DX4-100SV8B and A80486DX4-120SV8B and X5-133 cpus works at their intended frequencies. And all other cpus from U5S-40 to Cyrix 5x86-100GP in my inventory.
Did you use the exact same jumper setting for the A486DX4-100SV8B as for the Intel DX4-S?
EDIT: setting the multiplier of a DX4-100 to 2 is a pure hardware setting as far as I know.
The only way to do it, is to set JP21 to 1-2 on this board, if I read the "partial documention" of retroweb correctly.
So when this is not set and the DX4-100 is running at 66MHz (not only reported by Bios, but really!) , then it is 100% a mystery.
If yes, please make a picture of your Intel DX4-100 from both sides up and backside.
More EDIT: I am asking for that, because it only can be a fake CPU in that case.
EVEN MORE EDIT:
Before taking a picture from the (fake) intel DX4.
Run either speedsys or cachechk. Both programs are able to show the amount of L1 cache. An Intel DX2-66 has 8kB of L1 cache, where an Intel DX4-100 has 16kB of L1 cache.
Please add a picture of the output of those 2 programs to your answer.
When L1 cache shows up with 8kB, then of course add pictures of the CPU itsself as requested by me above. I never saw a fake Intel DX4-100. Would be a good fit if the board has fake cache though.
