Reply 52240 of 53143, by Trashbytes
- Oldbie
PD2JK wrote on 2024-03-22, 21:37:BitWrangler wrote on 2024-03-22, 17:33:PD2JK wrote on 2024-03-22, 15:30:Massive card, not full length but it is heavy. It could use some anti sagging clips.
WiNRADiO WR-1000i
Heh, I thought "That better not be just an FM card" then zoomed in to see it's actually rather decent frequency coverage. Looks like fun, like earlier incarnation of those SDR dongles you can buy for USB. Yah, I'd probably buy one too if it was in front of me, not sure I'd hunt one out though unless I got a project in mind.
Do you know what software you can use with it, or are you stuck with some ancient weather sat decoders for DOS or using GNUradio in linux?
The Winradio software should even work with Windows 7 32-bit: link.
The plan is to get it working in Windows 3.11, in a DX4 system. I'll hang a simple dipole antenna in the attic and have fair reception, wandering the bands.
Thats quite a famous card you have there made in none other than the Rosetta Laboratories right here in Australia, That card is IIRC one of the first they produce in 1996. Totally worth keeping and looking after it also still sells for quite a bit of money.
From what I can dig up this card was produced by Rosetta for Military usage so it should be extremely robust, Good solid bit of Aussie kit you have there, makes me want one now.
