First post, by kotel
- Member
Hi
I recently got this Wester Digital SCSI drive model WDE 4360 as untested. After powering on the drive tries to spin up, but can't. After a while of failed attempts, it makes a loud beep sound, then tries again and stops. I suspect it could be stuck bearing or heads, but I'm not sure. Anyone knows what could be the issue?
"Driving a tank is like a box of chocolates. You never know when you blow up"
- Someone from a tank game
