Reply 20 of 33, by QBiN
- Oldbie
Just as an FYI... I have found the following two PSU's currently being sold that still support a -5V line on the ATX 20-pin connector. I'm sure there are others out there. This was just a quick pass through NewEgg to see what was available and somewhat cheap. You should be able to find these at your favorite online computer shops without too much trouble.
StarTech ATXPOWER300 300W ATX Power Supply
RAIDMAX RX-380K 380W ATX12V Power Supply EDIT: DO NOT BUY. NEWEGG PHOTO IS OLD. NO LONGER SUPPORTS -5V.
EDIT: Update to available -5V supplies.
