Lylat1an wrote on 2024-04-10, 19:34:
I'm considering replacing capacitors on old hardware as a side-gig, but I haven't done it before.
Aside from my inexpensive multi-meter and adjustable soldering iron, will I need any other equipment?
For cap. replacement or other similar level of repairs I'd recommend the following:
Component replacement & Testing:
Adjustable temperature Soldering iron - basic chisel tip is fine for most work
Fume extractor
De-soldering gun - if you plan on doing a lot of recapping, highly recommended getting a proper de-soldering gun
Leaded solder + flux
Multimeter
ESR meter
Pliers
Fine-tipped tweezers
Flush cutters
Kapton (heat resistant) tape
Board holders / Vises - I really love the PanaVise board holder; great for recapping motherboards (see previous post)
POST Diagnostics card
Misc equipment (cleaning, corrosion removal):
Basic magnifier for inspection
Burnishing tools and/or Dremel with various sanding and polishing tips - good for corrosion removal
Disassembly tools (screw driver kit, prying tools)
Cotton Swaps, Paper towels
Solvents (IPA, Deoxit)
Anti-static brushes
Storage, etc:
Storage bins
Tool storage - shelves, pegboard, bins, drawers, etc.
Personal protective equipment - gloves, mask, especially if using chemical solvents and glues
Good lighting and power outlets
Workbench with a descent surface to work on
Also, are there any tutorials on the subject that you guys would recommend?
Mr. Solder Fix is my favorite YouTube channels for solder repair videos: https://www.youtube.com/@mrsolderfix3996
As you mention you haven't done this before, you're going to want to get in a lot of practice before trying to make this a side-gig.
And if you haven't done so, research different capacitor types, markings, what types of caps can be substituted and when it may be advantageous to do so (e.g. polymer instead of electrolytic), etc.
