First post, by Alex_03
Hello folks,
Yesterday I grabbed this Commodore Amiga A2386sx PC bridgeboard from a bin of scrap electronics, it has a 25MHz 386SX on it with what is likely 4MB of ram. Unfortunately it had a Varta NiCd battery on it, which as you can see leaked onto the board. I removed the battery and scrubbed off as much of the corrosion as I could to survey the damage, at first glance it doesn't look too bad, but in reality there are many cut traces and several questionable vias. If this was only a double sided PCB I may put an attempt in at repairing it, but this has 4 layers so there are buried traces coming off of vias.
With that being said, I don't want to try to repair it. However I figured it wouldn't hurt to ask you folks if there is still anything of value here? Parts? chips? PALs/GALs? If somebody wants this whole board as a parts unit it can be theirs for the cost of me shipping it too them.
Reply 1 of 14, by theelf
Ohhh too bad im on Spain, i was looking for this board for YEARS, i will love to try repair!! since was a kid i wanted one
Will be cool to make a A500 slot to zorro II!
Reply 2 of 14, by Deunan
Alex_03 wrote on 2024-05-05, 17:48:
Just for parts there isn't much here, there are some RAMs in unusual packages but those are difficult to desolder (and you don't want to overheat them). PALs are one-time programmable so of little use, except for direct replacement like the VLSI chips. Don't remove them out of sockets because in 2-3 months you'll forget which is which. Photos help but if you put them in a box it'll require fishing them out later.
I think selling the whole thing for shipping costs would be the best thing to do. I'm not much of Amiga fan though 😀
Reply 3 of 14, by Jo22
Deunan wrote on 2024-05-05, 22:42:
To be honest, I'm not even sure if I had used it if it was working.
The Janus software does merely support CGA and MDA (no Hercules!), so there's little of 286/386 era software that would run well.
The lack of VGA is severely limiting the use here (an ISA VGA card can be installed, but it requires its own monitor).
Any software emulator is more feature-complete here, maybe.
Or any other bridge board (Golden Gate etc), maybe.
Memory managers can make use of a 386 processors, though.
Windows will also run in 386 Enhanced-Mode, of course. But with CGA graphics..
That being said, saving the PALs might be worth it (if the Amiga community hasn't made backups of them yet).
It could help other bridge board users to fix their boards. 🙂
These are just my rwo cents, of course. I know very little about Amigas by comparison.
Reply 4 of 14, by Alex_03
These are actually socketed, so not difficult to remove if I wanted to.
Reply 5 of 14, by AlessandroB
You have PM
Reply 6 of 14, by bakemono
Jo22 wrote on 2024-05-05, 23:00:
Common use of bridge boards is just to run a shim program which allows the Amiga side to utilize an ISA ethernet card, which are more common than Zorro ethernet cards.
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 7 of 14, by Jo22
bakemono wrote on 2024-05-06, 14:11:
Good point, I remember. Getting access to cheap AT-Bus HDDs was one of these applications, I believe.
But still, the Commodore bridgeboards were a bit overpriced and didn't do PC platform any justice.
And the lack of Hercules support is something that still bothers me.
I'm ashamed of those Commodore engineers who thought that plain IBM™ MDA was good enough (CGA isn't worth being mentioned).
Because it doesn't (didn't) reflect reality in any way. Even if the Amiga didn't have the screen resolution, a virtual screen with scroll bars was possible.
In fact, I do have an 1980s laptop here, which does feature this. It's the Halikan 286.
Sometimes I wonder if this was done on purpose, so that Amiga fans could continue to make fun of PC hardware.
On the other hands, the Commodore bridgeboards never really evolved, were deeply stuck in the past.
Everything was based on that A2088XT PC card. Which itself was being based off that A1060 sidecar, I assume.
PS: There are pass-through cards, also, I believe. So the Amiga side can see the ISA slots. Golden Gate II is such a card, I think.
There's a video: https://www.youtube.com/watch?v=1dFLsT5T0RQ
I have no experience of such boards, though. Not sure how good they were.
Edit: By "CGA isn't worth being mentioned" I meant in a business context, I didn't mean to sound snobbish.
I mean who buys an extremely expensive PC emulator hardware (more expensive than the Amiga itself) just to play Alley Cat?
If there's anything an Amiga power user misses, it's not a low-end gaming experience, but PC productivity software (ACAD, floor planning software, Word perfect, Lotus 1-2-3).
Or business "games" to a stretch, like golf simulations, strip poker, ms flight simulator or a professional chess game.
Niche games not natively available on the Amiga platform.
And that's were Hercules was very important, simply. It was monochrome, but hi-def.
Psion chess in Hercules mode looks way more elegant than in CGA, for example.
To an avid chess player, this might be important.
Edit: To give an idea how awesome Psion Chess and Hercules graphics could be: https://www.youtube.com/watch?v=xx2aNlTqzvs&t=660
Reply 8 of 14, by Mr_Magoo
Hey Alex,
Is this card still availlable? I would like to consider taking a look and if possible, trying to repair. If it's not possible, there are other possibilities, since empty pcb's are availlable.
Let me know, what you would like to have for it.
Thanks and have a great day!
Reply 9 of 14, by Alex_03
Mr_Magoo, you can have it for whatever it costs for me to ship it to you!
I will send you a private message with further information.
Reply 10 of 14, by Mr_Magoo
Hi Alex,
I'm sorry, but due to the fact, that I didn't have enough postings to answer your PM (stupid function imho), I'll give you my mail directly. Doesn't matter... you can write me to mgustin (at) hispeed (dot) ch
I surely will add something to whatever amount it costs to send it to my address - you'll not regret it.
Even if the outcome will be to have it only on my display shelf - it's a nice piece of hardware and I will be more than happy to own it!
If there is any possibility to rebuild the card, I will do so and will also report it in here!
Thanks for making an (getting older) man happy!
Cheers, Mario
Reply 11 of 14, by Mr_Magoo
Hey Alex!
I'm still trying to get enough posts to write you back on your PM... Sorry, but that's a really nasty function, to avoid composing an answer to a PM...
If you didn't wrote to my mail (above), please give it a try, since it would be much easier to communicate.
Thanks dude!
Reply 12 of 14, by Sanxion
Hi Alex,
I am considering building a new 386 bridgeboard so if this is still available, I would be interested.
Thanks.
Reply 13 of 14, by Mr_Magoo
Hey Sanxion,
I got the Board from Alex, so nothing to get from him, but if you're interested, I can look for the address of a guy who makes the mainboards
for the Remake A2386.
Cheers!
Sanxion wrote on 2026-03-22, 17:05:
Hi Alex,
Thanks.
Reply 14 of 14, by Sanxion
Thanks Mr Magoo, but without a donor board containing the custom ICs, building a new one would be very difficult indeed.
