First post, by LequaRex
First off all, I tested the module and DOS won't boot. I took it out and when I looked at it, I saw, that the resistor network RN16 was in half (this module was purchased as USED on eBay [no defects listed]). I desoldered it and part of the circuit wire came with it... I'm pretty sure I can bridge that tho. It had a 220 on it (I assume that means 220 Ohms?). It looked the same like those four others you can see on the bottom of the module.
