Will the Book 8088 be a future classic?
Reply 322 of 368, by rasz_pl
Really nice. Dude is speedrunning being Acer/Compal 😀 At this pace he will be making new Pentium based Laptops next year 😜
Reply 323 of 368, by BitWrangler
n0p wrote on 2024-03-30, 12:35:
***THUD***
Well I missed the hand386...
    43.12 KiB
    She said yes, and I ordered :-)
Reply 324 of 368, by BitWrangler
rasz_pl wrote on 2024-03-30, 14:04:
Heh, though for obtanium, I'd bet rise/geode industrial 486ish SOCs with 200Mhz for Pentium class performance. IDK what would be the best way to go, but "what you can get" is a large consideration.
Edit: vortex86 maybe, that was one I was trying to remember.
Reply 325 of 368, by rasz_pl
BitWrangler wrote on 2024-03-30, 15:24:
Yes, judging by M6117 used here next could be DM&P Vortex86
Reply 326 of 368, by BitWrangler
Thread started for Pocket 386 info and chatter so this one isn't derailed.. Pocket 386, the brother of Hand386 and Book8088, the story so far ...
Reply 327 of 368, by betamax80
I probably wont be popular but I have ordered a PicoMem board - I'm really looking forward to seeing if it works with the Book8088. I need to flash @n0p BIOS v1.0.6 first though just to give it the best chance.... and actually I have the replacement LCD driver board to install too.
Reply 330 of 368, by STrRedWolf
betamax80 wrote on 2024-04-30, 22:43:
Can anybody help me with an adjustment to Serhii's BIOS? I need my PicoMEM ROM to be loaded AFTER XT-IDE whereas it currently overwrites the PicoMEM ROM so it does not load.
@nop are you able to help?
Reply 331 of 368, by KarlG
What is the max usable speed of the COM port on these things? I got a wifi modem, and it seems to work at 38,400, but I had some issues with some random garbage characters here and there when I went to a BBS, so I'm wondering if I was pushing it a bit too fast?
I know I can find out via trial and error, but I was wondering if anyone knew what the "correct" setting should be. 😀
Reply 332 of 368, by BitWrangler
Back in the day we'd assume regular XTs to top out at about 19,200 based on 8088@4.77 and 8450 uart tech. This was going through DOS/BIOS routines. Some utils existed to hammer on hardware directly and get more like 38,400 .... and that was kind of the generic reliable limit under DOS/BIOS with AT until 16550 UARTs will 33Mhz plus CPUs. Some machines were more optimised, and 3rd party serial cards could be better, but that's about what "generic" hardware did.
So I'd tend to think you are doing quite well to get 38,400, parity/error correcting options might help for the odd dropout, but if you want rock solid, you may have to drop it a peg, or upgrade to V20 and see if that helps.
Reply 333 of 368, by Jo22
It's possible to do 115200 Baud, at best. But it depends on software and hardware environment.
If the application has full control, if there's no interruption, it can work. Even on an XT (Turbo, ideally) with an i8250.
There's one program that I know can do pull that stunt, it's Ultrafast Filetransfer Operation from the mid-80s.
It can copy/retrieve files over V.24 port. Screenshots here
It was being made in a time when the IBM Model 5160 and Model 5170 (6 and 8 MHz) were still commonplace.
Again, this works if no interruption is happening (clean boot up disk).
A radio-controlled clock (serial dongle) or a network software may mess things up enough to make things fail.
In such a situation, 57600 Baud are possible as a fallback.
In case of Ultrafast Filetransfer Operation, I mean.
Reply 334 of 368, by KarlG
Jo22 wrote on 2024-05-10, 19:07:
JFYI I did get your PM, but I still don't have privileges to send PMs or even reply to them. I'm thinking that I need 20 posts, so letting you know this brings me a little closer, at least. 😁
Reply 335 of 368, by Jo22
You're welcome. ^^
Sorry also if I was being to chatty again. I just thought telling the technical background would be interesting, also because it uses 3-wire connection.
The operation of the utility as such is really neat, almost *nix like.
If started from deepest directory (ufo *. *), it'll transfer all higher ones w/ files, for example.
The only other utility that comes to mind right now is File Maven v3 (Freeware).
It also has one side waiting for communication, while the other side is doing work.
Anyway, I just thought this information would be interesting, especially to XT users:
A serial connection can be quickly established, doesn't take away much memory.
File Maven works best with a fully wired null modem, though, maybe.
Reply 337 of 368, by Jo22
KarlG wrote on 2024-05-11, 16:41:
In this case, I'm using a Wifi modem, however (WiModem232 Pro). I imagine a direct null cable connection with a utility like that would be much "cleaner", though.
That's a cool little thing! 😎👍 Should work just fine.
I guess I've simply have a soft spot for null-modem cables. 😅
I've used to build them out of shielded microphone cable, for example. It's 3-wire, essentially (mic, ground, shield - aluminium foil or a flexible wire mesh).
I admit, while it's both neither ideal or professional to use here, maybe, it can do 10m for sure.
By comparison, by using a reel of thick power cable (3-wire), my dad used to build null-modem cables of ~20m of length.
He had also built full 7-wire (?) null-modem cables with both pairs of hand-shaking lines.
Such a cable would be fine for File Maven, for example.
Anyway, I'm afraid I'm talking a bit too much again here. 😅
    31.85 KiB
    "it came from the 80s" (my dad's DB-25 null-modem cable, made ca. late 80s/early 90s)
Reply 339 of 368, by BitWrangler
Interesting, looks like it may share case and screen, maybe video adapter with Pocket386. Vid is showing CPU recognising as V20, not sure if that means that is what it is coming with, or that was a tester, or it has a more integrated chip like the P386 does so maybe one with V20 core like V40.
