What happened to the Spez FTP archive?
Reply 20 of 27, by kixs
What's so special about this FTP?
Reply 21 of 27, by debs3759
It's just another site with lots of files. I download and merge from all sorts of sites 😀
Reply 22 of 27, by kingcake
I have never had the supposed built in FTP in Win10/11 actually work. It always gives errors. Good old Filezilla will work no problem.
Reply 23 of 27, by Grzyb
The command-line FTP client provided with Windows still lacks passive mode, which makes it pretty much useless.
Reply 24 of 27, by Deunan
Grzyb wrote on 2024-05-15, 21:55:
And the port is harcoded to 21 as well. It's beyond useless.
Reply 25 of 27, by BitWrangler
I've been using the CoffeeCup Free FTP https://www.coffeecup.com/freestuff/ ... I can tolerate it... IDK depends what you're used to, seems as good as the win3x trumpet ones from back in the day.
Reply 26 of 27, by AngelaTheSephira
kingcake wrote on 2024-05-15, 21:06:
Except it's not working. Everything is failing to see that IP at all or even get DNS for it on my home network.
HP OmniBook 600CT
i486/DX4-75 | 16 MB RAM
800x600 full-colour LCD
256 MB CF card in a PCMCIA adapter
Reply 27 of 27, by BitWrangler
One thing that happens is that one IP can have 50 hosts on it, and one or two of them are porn or nastier, then ISPs and some nations will block them and the IP. Or family safe features in some routers, or by deliberate choice of DNS provider do.
